Question about Sanyo DP32746 32 in. LCD Television
Sanyo LCD TV DP32746 no picture
Picture went black, sound is good. Assume from my research CCFL(s) are bad. Attached is a picture of the set with back panel removed. Could it be the Backlight Inverter? Guess it makes sense to change the bulbs first since they are less costly. Appreciate your help greatly. Brad no picture
    Problem Solver:
  • 14 Answers
Hi Sandy
Yep, after doing a little more research, I've come to the same conclusion, however they have more than half a dozen different Back light inverters for these Sanyo units, hopefully its not the most expensive one and not the one my supplier does not have in stock, trying to give my customer an estimate, hopefully I don't have to shoot too high. Thanks for the info.
Posted on Aug 05, 2012
  • 71 Answers
Change the backlight
Posted on Mar 05, 2009
No sound on t.v. but popping and crackling from speaker
Sanyo sets have a horrible track record, if the set is still under warranty return it. The problem could be in either the power supply or main board. It will have to be diagnosed properly to be sure.
Oct 22, 2012 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 no picture, sound good
If there is still sound its the back light inverter, if no power at all its the ccfl
Mar 17, 2008 | Sanyo DP32746 32 in. LCD Television
My Sanyo DP42848 has audio but no picture. How can I fix it?
i turn my sanyo on and its all good for a few seconds then i loose picture but still have sound ,,whats wrong?
Jan 21, 2011 | Sanyo DP42848 LCD TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
The picture is out totally but have sound
Easy way to Diagnose is get a known good CCFL from a laptop or LCD TV and start plugging it in to the existing Cathode's Ports one at a time. Generally its a bad CCFL on these multiple units.. (2,4,6) Bulbs.. Moniserv.com for replacements.
Goodluck guys!
Aug 17, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Mar 01, 2009 | Sanyo DP32746 32 in. LCD Television
The power button lights up but no sound or picture.
Check to see if the set is under warranty or an extended warranty.
If not, ouch, but do-able.
From least to worst case, possibilities include
1. Bad panel drivers (between the Y-Sus PCB and Panel)
2. Bad Y-Sustain board or equivalent.
3. Bad power supply.
4. Control PCB.
5. Bad Panel.
Or any combination of...
I would recommend that you have a certified and factory authorized technician repair your set. Or at least diagnose it. Not always is it just replacing a board. There are adjustments that need to at least be verified by a knowledgeable technician.
Wouldn't want to get zapped. There is High Voltage back there.
You might also try entering the make and model number of your set online to search for others with like problems on the same model. Odds are that it has happened more than just once and that other techs may have a definate solution to your problem.
Just takes a little research.
Good luck.
Tim
Certified TV
Jan 11, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 TV won't turn on
Sanyo 32" TV has no Picture sound fine.Model DP32746
Dec 03, 2008 | Sanyo DP32746 32 in. LCD Television
Goodluck guys!
Sanyo lcd 32" vizion integrated hdtv
I have this tv as well with the same problem. From the research I've done, one of the 16 ccfl's(backlight bulbs) goes bad and they all will not come on then. I have not been able to find a replacement ccfl for this particular tv. The ccfl size if 3mm x 711mm. I have a feeling the scope of this problem is very large with this particular tv and this forum represents the tip of the iceberg. Sanyo unfortunately makes a piece of junk and we have that piece of junk sitting in our homes with no good solution other than to say, dont waste your money on another Sanyo tv.
Jan 09, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 32 in. LCD Television Logo
494 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
