Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Have a bissil proheat clearview plus model 1699-1,there is no water flow. soap seems to work. It was used one time but the system was not flushed. Has not worked since.
  • wpd132 Nov 22, 2008
    I have the same problem, how do I unclog the heater?
  • Anonymous Dec 16, 2008
    I have a 1698 and have the same problem. Is there any way that I could get a use & care book for this modle?
  • 37 Answers
If you have spray through your hose and no spray on your carpet then your heater will be clogged with soap. try this and post later if thats not it.
Posted on Sep 27, 2008
Model 1699-1 ProHeat Clearview Plus -water and cleaner do not dispense when using trigger on handle. The turbobrush hand tool works fine.
When it doesn't dispense water an cleaner like that it means that the pump belt needs to be replaced. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do i put new belt on
Here is a link to the manual and to the belts you need. hope it helps!
Bissell ProHeat Manual and Belts
Nov 21, 2009 | Bissell 7901-R Clearview Proheat Plus...
Why wont my bissell proheat clearview dispense soap?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rw
Nov 17, 2009 | Bissell 1699 ProHeat Clear View Upright...
Water spews out of flow indicator
yes you can buy just the cap go to bissell's website and you should be able to order it yourself, it just screws off and on.
Sep 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View uses very little soap.
The valve at the bottom of the soap tank may have gone bad, Also try running a mix of water and vinegar(not on carpet) to see if it will clean the system out. The system may just need cleaning out.
Jun 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
My bissell powersteamer clearview will not **** up water
Check the heater inside of the handle, it may be clogged and not allowing water to flow. The hose doesn't use the heater and that would be why it flows out the hose.
Apr 13, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clearview Steam Cleaner won't pick up
Usually if the water isn't being sucked up is either the filter in the lid of the tank is clogged, or the gasket that sits on top of the clear window nozzle and the tank is missing.
Jan 08, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
282 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
