SOURCE: Fabric Softner section won't fully drain....
take your soap draw out pull the fabric softener tub out wash leave all of your soap draw in a bucket of hot water scrub with a brush this should clean a small hole which lets your conditioner out simply fix common fault m8
SOURCE: Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
SOURCE: KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
SOURCE: Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
SOURCE: Fabric conditioner dispencer not working
Dispenser trays have a narrow hole at the base of the unit.. this is most likely blocked with gunge... pour bleach into outlet and push a straw through to clear obstruction. Once cleared take drawer out of machine regulary and wash in hot soapy water to prevent a repeat buildup.
