Question about Goodman Heating & Cooling
My goodman seer 13 package heatpump stopped blowing cool air. Fan still works, there is power to the unit.
  • 1,420 Answers
Is the outside unit starting and fan blade spinning? Have you inspected you air filter recently?
Posted on Sep 15, 2008
Difference in seer
i would check fan speed. it's probably on high. you might be moving more air with new system. a dirty evaporater on old unit woud have gave you a larger temperture drop.
Jun 16, 2014 | Goodman Heating & Cooling
Goodman package heatpump blower motor contant running
check your themostat fan mode switch to see if it in on or auto. It should be in auto. If this does not stop indoor fan motor, (it may take up to 2 minutes for the fan to stop, preprogrammed shutoff in the thermostat and fan control cards may make you think the fan has not stopped ) If this does not stop the fan the fan control board in your air handler has a green wire shorting to 24 volt signal in the theromostat wire or the contact on the blower control card is stuck and will need replaced.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Will not come on but emergence heat works
Check contactor that operates compressor and condenser fan. Does it try to come on when you first turn it on, or just sits there? If it tries to come on, it could be the capacitor.
Jan 25, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Blows little heat
Check the filter & indoor coil...could be plugged up.
Dec 13, 2013 | Goodman Manufacturing Goodman GPH1360M41 5...
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
A/C fan is running but no cool air
Make sure the outside unit is running. If it is then you may need to get the unit charged.
May 02, 2010 | Goodman CPLT24-1 13 Air Conditioner
Just had a new 3.5 Ton Goodman GSZ13-13 SEER, heatpump installed. Its working OK in Cooling, however whe switched over to heating mode the indor unit makes a loud grumbling sound. The installer stated that...
I install them every day and I have not had one make a loud grumbling sound. Sounds like you might have a low voltage (Thermostat) wiring problem. The only thing different inside the indoors unit from heat and cool is the fan speed, electric heat when on. The fan might be loose or out of balance and it only shows up at low speeds. Either way, the noise is not normal.
Oct 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Is a goodman gsc139421ac a heatpump
13 seer 3.5 ton unit check inside condensing unit for reversing valve. Also open panel and see if it has a defrost board. It is located above the contactor. Rusty
Jun 04, 2009 | Heating & Cooling
I have goodman 13 seer/ I have power going into the unit and it will not pull in the contact and when i push in the contact the fan will run but not blow in the house and both cooper pipes on the outside...
check power on the 24 volt coil of the contact pushing in the contactor will not make youre blower in the house run only start the compressor and condensing fan on the outside unit. if u do not have 24 volts on the coil of the contactor that could mean a few things high or low pressure switch is open. which this sounds like the problem because you stated the unit starts but both (copper) pipes stay warm this may be cause by no freon in the system. see normally if you push that contactor in when the indoor fan not running u will get really cold big pipe thats called the suction line. check if you have voltage on the coil when unit is calling for cooling if not look at the schematic and ohm the pressure switces if there are any
May 28, 2009 | Goodman CPLT24-1 13 Air Conditioner
Heating & Cooling Logo
332 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
