Key boadrd problem in canon np 7161
Hi my expert ginko.
my problem is the keyboard in canon np 7161 and i comfirmed this after replacing the key board of the other machine also canon np 7161.
indication from the said key board (the bad one) is control card and the right door open at the same time once you switch on the machine.
as you know the key board has only the resistors, diodes,led, jumpers (wires), the 8 segment display, switches and 3 plugin connectors.
I measured all the components by digital multimeter and i found northing bad. Can you tell me the excactly components that can course this problem? may the 8 segment display the problem?
pls help me through my Email: khakhamis@yahoo,com
  • vendeline Silayo
    vendeline Silayo Dec 13, 2008
    hi ginko how are you today? can you help me out with my canon 7161 key button is not responding at all after replacing toner
  • Anonymous Mar 17, 2014
    problem display is code e001 what i can do
If You trust me ... then do it i had the same problem after too much hard work i found the LEDs was causing the problems just trust me and replace all the LEDs on the panel card ....
and remember me in ur prayers thanks and regards
contact me for further
jak1980_pk@yahoo.com
country Pakistan
Muhammad Ali
Posted on Mar 27, 2009
  • 19,396 Answers
I did not understand in deep what is wrong with the printer, if the conntrol board is malfunctioning then, often the touch buttons on control board are probably faulty.
We generally do not even bother to test them, when one or two button do not work we check the connector, usually a ribbon cable, then we replace the control panel assembly.
If you want to test the buttons, the easiest thing to do is checking signal at the ribbon cable connection cold solder joints.
Posted on Sep 15, 2008
Canon np 7161 photo copy machine error code 010
  1. If Cause of connector
All are The connector if not connected then Reconnect it.
2. Cause of Power Supply PCB.
Turn on the power switch. Set the meter
range to 30 VDC, and connect the probes to
J209-4 (+) and J209-3 (-) on the DC
controller PCB. Is the voltage about 24 V?
Suggestion:
See
"DC power is absent.Power Supply PCB is faulty
3. Cause Of Main Motor(M1) or DC controller
Replace the main motor. Is the problem
corrected? If no..Then
Replace The DC controller
Jun 30, 2016 | Canon Office Equipment & Supplies
Canon 7161 error 805
• The exhaust fan (FM2, FM4) is faulty.or
• The DC controller PCB is faulty.
See Chapter 10 page 101 of the service manual You can download the service manual for the Canon NP 7161 from here See chapter 10 page 101
http://monitor.espec.ws/files/np7161_sm_123.pdf
Dec 29, 2013 | Office Equipment & Supplies
E102 np 7161
If this is a canon copier then the E102 code means that the scanner lamp is bad or the laser unit is bad... Scanner lamp is a simple repair job for a tech. Laser Unit is a lot of labor. This can get expensive fast.
Canon Parts And Supplies
Sep 13, 2012 | Compatible Office Equipment & Supplies
Canon np 7161 E004 error
Ok let me help u on fixing your problem.
mostly this error is in fusing unit and may be due to power disturbance.
first press * (star) then 2 & 8 together again *(star) if succesfully u presed 2&8 together and then *(star) the number 1 (one) will appear in the box [ 1 ] then press 4 then A (automatic exposure) then 412 and finally finnish by pressing the start button/print button the machine will go OFF turn it ON it is now ok. if not start again follow the sequency untill to the step of pressing the start button insted of it press A.
try your best, kibokoyao waiting for your vote.
Apr 26, 2012 | Office Equipment & Supplies
On Canon NP 7161: what's the 123 symbol flash mean? And the clear powder also flash but it new one empty. Please help
The "123" symbol is that you need to insert the key counter or you need to deposit a coin. It is a control funcation for using the copier.
Sep 09, 2010 | Office Equipment & Supplies
A canon np 7161 with an e002 error code. It is my
ok let me help u on fixing your problem.
Apr 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
Canon np 7161 simulation
hi help me with this formula to reset canon 7161 e0003 is *2&8 at a go, then * then A then 412 is this the correct way. ?????
Jan 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
223 people viewed this question
jasbo
jasbo
