Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis elite he
Full of water and clothes. "ld" error.
lid will open but nothing will get the machine to finish the cycle.
Tried all the buttons, nothing happens.
It was initially beeping every few seconds and I couldn't get it to do anything so, I unplugged it and still nothing happens.
  • m_james1313 Sep 16, 2008
    Thanks,
    I drained the water, removed the back...
    I can see the drain area, see lint etc. how do I get that clean?
    It is attached to the whole case. I can barely get my finger in there after removing the little hoses...
    I have the washer on its side and can see all.
    Mark
    P.S. I had left the washer unplugged over night and turned it on again with same results.
  • 5,911 Answers
Have you tried leaving the washer unplugged for at least 30 minutes? The manufacturer recommends, first unplugging the appliance for this duration to reset the control board. In some cases this will correct momentary glitches. If this does not resolve your problem, you will need to inspect your drain pump. The "ld" error code is a Long Drain problem which is usually an indication of a clog in the drain pump or drain line, or a failed drain pump. This model washer has two pumps, I believe. One is a recirc pump, the other is the drain pump. The drain pump is below the wash tub on the RIGHT hand side (as viewed from the front of the washer). The way you access the pump is by tilting the washer backwards and working from underneath, or by removing the back panel of the washer. In order to safely tilt the washer, however, you will need to drain the wash tub. The easiest way to accomplish this without bailing is to remove the drain hose from the standpipe at the wall and pull a vacuum on the line with a wet/dry shop vac. You will need to empty ALL residual water in order to remove the drain lines to inspect the pump. If you do not, be prepared to mop up a lot of water. Your washer has one of the largest wash tubs available.
There is also a tech sheet inside your washer with all the error codes and recommended troubleshooting advice. You can access the tech sheet by locating the release tabs along the front of the washer where the top cabinet meets the front of the washer. About 2 inches in from each side you will find a tab in the seam. Use a putty knife and push straight in while lifting up to release. NOTE: This may require some muscle to do. Once you have the top free, hold on to the washer lid BEFORE you lift up the top or the lid will fly open. The tech sheet should be attached between the front washer case and wash tub.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 16, 2008
  • Jeff Rockwell
    Jeff Rockwell Sep 16, 2008
    You have to uninstall the pump by disconnecting the electrical connector, remove the mounting screws that hold it in place, and disconnect the hoses. It is best to do this by tilting the washer back and working from underneath. I know it can be difficult to get inside the pump and/or fittings. I have found a section of coat hangar bent with a small hook at the end works well.
Kenmore Elite Oasis Washer Error Code Ld
LD probably means the LID SWITCH has failed
Aug 10, 2016 | Kenmore Washing Machines
Kenmore 27042 Elite Oasis. When it goes to spin mode you will get a code LD. Open the lid and move the tub up and a few times then restart the spin cycle and then it will work.
Seems that the load on the motor during the spin causes more strain and so it cut off with a error code. Now when you move it will get free and so causes the spindle to free.
Now after wash check the spindle ,the bearings the motor drive, use some lubrication, use some spray to degrease( WD40) if this is seen to be tight.
If not reassmeble this section to clear the fault.
check for tips on how to remove from:
http://www.espares.co.uk/advice/washing-machines/a/7
Aug 08, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Sears 500 washing machine stops in middle of wash cycle.
timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to whirlpoolpartssurplus.com call .. ask for mark
Jun 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My washer has an error code ld and it wont start or turn off i have to unplug it to turn it off now its stuck on on how do i fix it
"ld" stands for long drain. check the water pump for any obstructed items like coins, hair pins or clothing. the water pump is located in the bottom of machine in right back of stator. remove hoses and clean. also check the air dome located in bottom of basket.
May 05, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer displaying "LD" and constantly beeps
Sometimes the LD on certain machines can be decieving, It's possible that the error is pointing to a lid lock issue. I'm a sears tech but have logged of my work computer for the night so I can't look it up right now. I just happened to stumble on this forum. In all appliances there is a tech sheet hid somewhere. This will give you more information. On this model, if you press and hold anykey for 3-4 seconds, let it up for 3-4 second and do that 3 times it will show more codes and go into a test cycle. Don't worry you cant screw anything up in the controller. If you or anybody needs help on appliances you can drop me a line. I have been a Sears tech for 15 years and have seen a lot of stuff and learning more all the time. scottowa at hot mail
Dec 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Machine went dead with clothes and water in it
with putty knife press in along front edge between top and front about 2-3 ins from outer edges on release clips top will lift up suspect bad lock assembly
Jul 04, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Error code LD
I had this problem also. Ld means that it is taking too long for the tub to drain, usually something is clogged. Try taking a shop vac and sucking out the drain hose that goes into the wall drain. This should at least get you where the tub will finish the cycle you have going. I tried this and it worked for about 2 loads then "Ld" again. Finally removed the drain pump from the washer and let it empty completely. So far this has worked.
Jun 10, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
216 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
