Question about Electrolux Vacuums
Where can I get my Electrolux serviced properly? I am in the Folsom area near Sacramento, CA.
  • 105 Answers
Mr. Appliance, Sacramento, Ca Phone# 916-436-8569
Posted on Sep 15, 2008
Apparetnly the fuse blew out. i was wondering where i can get one? the fuse number is 250u. is there a place or a website i can get the part. the microwave won't work or come on. i live in the sacramento...
Sorry to read about your problem, I hope this helps you out.
Radio Shack
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Vacuums
While vacuuming the red light for the bag of the vacuum came on and the vacuum stopped. The bag was no where near full so I replaced it with a new bag - same problem. It vaccumes for a minute or then stops...
I'm assuming this is the Epic 6500 or similar model.
Detach the hose, turn vacuum on. If it runs, place palm of hand against inport hole. If it shuts off the problem is with either the control valve setting or the control valve assembly itself.
For cvs, turn dial on top of vacuum all the way to the largest dot, and try above test again. If that doesn't work, then it's the CVA. It needs to be cleaned or replaced, which is an in shop job. Fro repair, take it to the nearest Aerus Electrolux store. I recommend a full clean and service to remove any dust/dirt from the motor, fan assembly, and other internal parts.
Another problem, which relates to the dial setting, is that fine dust will quickly clog the pores of the bag, resulting in the machine "thinking" the bag is full. Turning the dial to the proper setting helps get the bag fuller. The middle setting is the normal setting, and is for areas without fine dust and sand.
Dec 05, 2010 | Electrolux Vacuums
How to replace sheath cord on eletroux
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=840565
Generic problem for all Vacuums
Posted by ellie_pesca on Jul 27, 2008
How to replace sheath cord on Electrolux
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Just bring in a sample of the Electrolux sheath cord to your local vacuum cleaner dealer in your area and chances are he will have the part to replace the sheath cord for the Electrolux. Or you can contact the Electrolux factory website or the cust serv line and supply them with the brand name and model # of the vacuum and they can either send it out to you or let you know where you can get one. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 27, 2008 | Vacuums
I have Electrolux canister vac. The suction end pops open everytime it loads up.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689886
Posted by wmcox on Jun 20, 2008
I have Electrolux canister vac. The suction end pops open every time it loads up.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In the door there are vacuum lines that could be pinched or bent and are not letting air through to the bag, the system is designed that if the bag get to full or the air flow is restricted it will pop the door open and save the motor from burn out. This is repairable and nor to expensive and to check with the local vacuum cleaner dealer in your area or to call the Electrolux cust serv @ the factory for further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Hi, I have an electrolux Ambassador and the other day I was vacuuming a fringe carpet and the fringe made the electrolux stop (has happened before) and when I pressed the reset button, the motor is on but...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=678083
Hi, I have an Electrolux Ambassador
Posted by greenforest on Jun 17, 2008
Hi, I have an Electrolux Ambassador and the other day I was vacuuming a fringe carpet and the fringe made the Electrolux stop (has happened before) and when I pressed the reset button, the motor is on but the wheel does not spin. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are 2 possibilities that could be happening. Either the belt is broken of which you can replace the belt @ least one a year for proper maintenance or there may be a reset for the vacuum in case you get something caught in the brushroll section of the vacuum. Check both of those items and it should work unless you have a motor burn out – if you did there would be a burning smell. Feel free to contact your local vacuum cleaner dealer in your area.
Go Ahead. Use Us.
Jun 17, 2008 | Vacuums
Electrolux Ambassador stainless lower wand
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=638738
Posted by Cuyler on Jun 01, 2008
I am trying to locate a stainless lower wand for an Electrolux Ambassador model 1623. The search has proven fruitless so far. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. A couple of thought came to mind that you can try. Look in the yellow pages for your local vacuum dealer to see if they carry it to contact your Electrolux factory @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 01, 2008 | Electrolux Guardian Bagged Canister Vacuum
Electolux renaissance
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=576614
Electrolux renaissance
Posted by maryannn2l on May 06, 2008
No power when I plug into outlet
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may have 3 problems that I can see. You may have a bad electrical outlet, but I doubt it, the bad cordwinder cord or a short in the cordwinder itself, or a connection came loose in the motor section. If you need further assistance then contact your local vacuum cleaner dealer in your area or contact the Electrolux factory listed below. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
May 06, 2008 | Vacuums
The dustbuster part of my electrolux pronto 2 in 1 keeps getting stuck. I cannot eject it out of the main piece in order to use it on its own.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=543675
Posted by nrosener on Apr 25, 2008
The dustbuster part of my Electrolux pronto 2 in 1 keeps getting stuck. I cannot eject it out of the main piece in order to use it on its own.
Sorry you are having a problem, I would suggest that you take it to an Electrolux dealer or try you local vacuum cleaner dealer in your area, all it may need is a slight adjustment to the back of the dustbuster or the part that releases the Electrolux dustbuster, it may be to tight and would need and adjustment or replacement in order for the item to release properly. So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com Customer Service
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
Replacing on/off switch of electrolux
In yhe side of you canister there is a ruber molding on each side. Open the door to access the bag and you will be able to pull these two molding straight out this will allow you to split the canister.
Apr 24, 2008 | Vacuums
Vacuums Logo
179 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
