We have a Peavey RQ4332C that seems to work well with direct feeds but when using wireless anything, sparatically, we get interruption and distortion in the system. Help? is this the board or outside interference? Can it be fixed or should we look for a new board?
Usually this is caused by a cellphone in the area. The cellphones send a signal to the cell tower ever few seconds, when they do that, it makes it sound like the wireless mike is losing its battery, when in fact, it is the cellphone interfering with the signal. A simple test would be to power up the system when you can verify there are no cellphones turned on and try the wireless system. Then turn the cellphone on and repeat the scenario.
Posted on Oct 23, 2009
Wish to bridge onto mixer output to send to separate amp for use in another part of bldg. without interfearing with regular speakers. Peavey XR684
simple !! most peavey mixers have a monitor output !! you can use that to feed new amp , and theres your volume too !!! or if your already using the monitor output , you can buy a split cable (1 in 2 outs) for main send !! this cable would have to be kept short or it will induce HUMMM !! and in real extreme cases if your using a low Z send (cant think as to why ) a device known as a (direct box) normally used by instrument sends can be used in reverse to "tap" into a low Z send and output with a unbalanced send for an amp to your other room , but hey why not just add a speaker with a volume control to it for this smaller room ? and forgo the new amp
Oct 05, 2016 | Peavey Music
I have a TNT 115 S that is distorting when i play E string on my bass. What might be causing that?
Please add more information to improve help, does the amp just distorts in that particular note or teh entire sound is distorted? does the amp distorts at low volumes?
Sep 05, 2013 | Peavey Electronics Peavey Tour Tnt 115...
One channel distorted on my peavey 1200 watt amp
Sounds like your output stage took a dump!
Dec 18, 2012 | Car Audio & Video
Useing a Peavey XR 800F Powered PA Mixer/Amp which develops distortion on output after around 60 minutes. Also had gear linked to all inputs at the time, three mics, 2 guitars and keyboard. Any ideas...
First of all confirm if the speaker impedance is not lower then the recommended Ohms at the back of the Mixer speaker socket.You can use an 8 Ohms speaker on a 4 Ohms amplifier but not vise versa .
Next see if the fan on the mixer works. If not the Amp is getting very hot and this will lead to unwanted distortion. You can confirm if its a heat related issue by playing the mixer at low volumes for more than an hour and see if it distorts.
Apr 26, 2011 | Peavey Pv 2600 Power Amplifier
Distortion on the lead channel is not working
The intergrated circuit is most likely gone out. Not much you can do, cost in repair is more than the amp. Check out the peavey vypyr, it's a great modeling amp for about $100.
Jan 20, 2011 | Peavey Bandit 112 Guitar Amplifier With...
Panasonic DMR E20 Produces a line of distortion along the bottom
Sounds like you see head switching from the tape. Most TV are over scanned enough to hide it.
Aug 30, 2009 | Panasonic DMR-E20 DVD Recorder
Peavey Bass Amp TKO115s
Start with a clean setting - zero cut and zero gain on the Eq. Play a song close to the amp, and then move away, playing the same notes. Do you still get the distortion? Change lower the input gain and repeat the test. Lower the output gain and repeat. Are any outboard distortion pedals in the mix, such as overdrive? Eliminate them. Run straight through from your axe to the amp. Check for any distortion settings. Set everything including reverb to zero. When the distortion disappears, this is your base setting.
Change only ONE parameter at a time. When the distortion comes back, you have found your problem.+
Dec 03, 2008 | Peavey EQ215FX Home Equalizer
133 people viewed this question
 Grubhead
Grubhead
