Question about Coleman (100076) Compact Refrigerator
Coleman Powermate PM0545007 generator. A significant leak has developed at the point where the fuel shut-off valve connects to the fuel tank. The valve is mounted in a large rubber plug that fits into the fuel tank. That plug has become loose and gasoline leaks out freely. I've tried to press the plug firmly into the tank, but without success. Can you tell me if there is a way to secure or replace that rubber plug? The parts list for this generator shows the shut-off valve and the fuel tank, but does not show the rubber plug. Thank you for your assistance. dweb@dcwalls.net
  • dweb830 Jan 27, 2009
    Just got your reply today. Will give JB Weld a try.
    Thanks very much.
3 Suggested Answers
sal_kh_sab
  • 98 Answers
SOURCE: Need to replace fuel shut-off valve
well..the whole valve has a place where u can place a 12 or 13 size spanner...and then just twist it..
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Posted on Oct 16, 2009
  • 77 Answers
SOURCE: Coleman 564 refrigerated cooler - Need male plug. Where to find.
Replacement lighter plug / 12 volt accessory plug Male
Posted on Feb 07, 2012
bfroy61834
  • 12 Answers
SOURCE: Generator is leaking gasoline out through the
Most often fuel leaking out the carb is caused by a needle and seat problem in the carburetor / the float level shaft screw may have come loose due to the vibration of the engine ,this will cause a leak issue with the needle and seat as well. To complete the repair the carb will have to be removed and cleaned. Replace the needle and seat if necessary an then replace the carb.
Posted on Nov 20, 2014
Powermate PM0545007
With mine I add 'dry gas'. My local store carries Sta-Bil, yours will have something compatible (if not this one). Even if the gas is new, moisture can still be in the tank. Use as directed.
I use it in my snowblower, tractor, generator and cars.
Hope that cures your problem as it has mine.
Feb 03, 2013 | Coleman Powermate Premium Plus 6250W...
Where is the fuel shut off valve
Powermate generators usually have a shutoff mounted to the bottom of the fuel tank. There is a knob at the bottom of the connector where the hose is attached to the fuel tank. Screwing it in (clockwise) shuts off the fuel.
Aug 30, 2012 | Coleman Powermate Portable Generator...
Where is the fuel shut off valve on a coleman powermate 2500
follow fuel line from fuel tank to the carb if you dont find it it probably does not have one
Sep 04, 2010 | Coleman Powermate Proforce 2500 Generator
Coleman 6250 PoweLeaking gas at bottom of motor housing. Can not
The gas is leaking from carb but in the motor not out.
You should check and repair the carb flow valve. The floating unit may be full and bent down.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
My Coleman Generator Model 19G412 has a fuel shut-off screw/valve. It was in the off position. I needed to use the generator, but when I tried to turn the screw/valve to the on position, it would not turn....
explore the possibility of removing & replacing the 'petcock'[fuel valve] in the tank.drain tank,remove gas line,unscrew petcock retaining nut at tank & replace.
Oct 12, 2009 | Coleman Powermate Powermate 5000W...
Fuel leaks from around the valve at the 5 gal plastic fuel tank
you twist the whole valve after disconnecting the hose...
get a new one and put it instead...
if u have any further questions let me know:
Jun 29, 2009 | Coleman Powermate Powermate 5000W...
Need to replace fuel shut-off valve on Coleman Powermate Generator PMO525202. It has a 5 gallon plastic tank. How do I remove the original valve(without breaking something)? Thanks,
Jun 03, 2009 | Coleman Powermate Powermate 5000W...
Looking for a Pricesheet
google"coleman powermate". on the site look for manuals. the price list is the top manual. kinda small. you may have to increase magnification. mike
Nov 17, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman (100076) Compact Refrigerator Logo
379 people viewed this question
Top Coleman Home Experts
Donni Steen
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
