Question about Toshiba TZ50V51 50" Rear Projection Television
Toshiba Rear Projection TV Problem
Toshiba 61 HX 70 Not Turning on only Blinking lights. Before that Pictures was Glowing up and down and after unplugging the TV for Ten  min. Problem was solved. clicks on, power light comes on for a few seconds, then blinks. No picture, no sound
  • 125 Answers
Common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Posted on Sep 15, 2008
Blinking power light toshiba tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 02, 2014 | Toshiba TP61H60 61" Rear Projection...
Why is power light blinking
is it yellow as it blinks or red? if yellow check the kill switch located at the base of the lamp compartment cover ensure it presses the switch lever in order to ser the tv to standby mode the yellow blinking will stop and u will see a stable red ready for switching on
Jul 19, 2013 | Toshiba 61H71 61" Rear Projection...
My TZ61V61 rear projection 60 inch television turns off randomly. The red light by the on/off switch blinks. Sometimes the TV will still work though.
The blinking red light is telling you the code. Watch how many times it blinks. when it pauses for a seccond, watch again. Write down the number of times between each pause. Then repost with that info and I might be able to figure out what is wrong. Hopefully before it is permanent.
Jun 11, 2011 | Toshiba TZ61V61 61" Rear Projection...
Toshiba 61 rear projection, im not sure what wrong with it. One day it decided it wont transmit any pictures. The standby light is on but no picture. At first i thought i may be the remote not working, ive...
When was this tv has it projection lamp last replaced?If 1 1/2 or 2 years.Tv on an used like 4 or 5 hours a day.The projection lamp life is over.Require change another projection lamp.U hear alot of clickings too?That mean the board call the Ballast board it also dead,and require changing too.This Ballast board,help to ignite the projection lamp.
Aug 14, 2010 | Toshiba 61H71 61" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Red keeps going out but there is a new bulb in place.
red light keeps blinking on and off but the tv isnt turning on
Jun 02, 2009 | Toshiba TN61X81 61" Rear Projection...
61'' SONY Rear Projection KP 61HS10 blinking
My Sony HiScan 61" intemittent black screen for couple of seconds. I opened the back and look at what is happening. All three blue, green and red projection lights go off for a second or two frequently.
Anyone know what is the fix.
thanks
James
Mar 25, 2009 | Sony KP-61HS10 61" Rear Projection...
BLINKING POWER LIGHT AND TV DOES NOT POWER ON
I have a toshiba 61 inch projection tv the power light flashes with no picture any easy fixes?
Jun 24, 2008 | Toshiba TP61G90 61" Rear Projection...
Toshiba 50H71 projection tv
You need to replace both of the convergence ICs they are number STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions so you can do the repair yourself which tkes about 30 minutes to do and saves you about 400 dollars. heres the link.
http://servicemanuals.vstore.ca/
May 18, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba is one of the few sets that do not have a diagnosis feature built into the power light , Toshiba has to be able to light the screen to access its self diagnosis features. So you will most likely need the service manual to check the voltages in order to properly diagnose your set. You can get a service manual at the following link, and they will email it to you if you would like. here is the link.
Feb 09, 2008 | Toshiba 61HX70 61" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
183 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
