Question about Belkin Computers & Internet
HELLO I need help with getting my belkin working again it is showing only the wired light & the router light I need help on getting my belkin to run right please help me
    Genius:
  • 1,269 Answers
First, try to reset the router. Hold the reset button at the back of the router for 20 seconds then unplug the power. Make sure the modem is off as well. While the modem and router are off, double check your physical connection. Make sure the modem is plug into the Internet port of the router and your PC to port number 1. Power on the modem first, wait for the lights to go solid then power on the router. Check if the internet works fine.
Hope that helps.
Posted on Sep 16, 2008
My router was running and stopping for several days, then completely quit working. No lights come on at all--we've only had it since Dec what can I do
The best thing to do is try and reset it. This usually helps get it running good again.
With the router powered on.. Turn the router around.. There is a small small hole.. Inside that hole is a reset button..
You will need something small like an unfolded paperclip, or, sometimes the tip of an inkpen will work.
Press into the hole, and press the reset button inside the hole untill the routers lights flash at once for a second together, then go out..
Once this is done, unplug the router, then plug it back in ( power cord)
The router will be reset.
Your wireless network will work, but it wont have a password. To set a password again, you will need to run the setup cd that came with the router.
KittyTech
Mar 09, 2011 | Belkin Basic Wireless Router
I can't figure which wire goes where\w my Belkin Router. There's no manuel to show me how, or where to put the wires!
1.Please look on the rear end of the router you ll see 4 grey and one yellow slot
2.The ethernet slot from Your ISP Modem(Eg Motorola or westell)should be connected to yellow slot on the belkin and computer to one of the 4 grey slot
3.Run the Set Up CD :
4.Check for the light status : It should be green
Which means the router is all set and good to go
Jan 07, 2011 | Belkin Basic Wireless Router
Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Nov 12, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
The light with the globe is constantly blinking
If you tell me the version number of your Belkin mimo wireless router , i will fix this issue.Any Routers issue contactme,, i will help you out. copy and paste this URL to your Browser http://techhobbies.blogspot.com
Feb 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Everything is plugged in, but its not working.
Run the cd utility to install the soft for your router
Nov 19, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin G plus MIMO router - Red light
after a while the use that is put to the router will decline
and will get worse as multiple devices are making it work hard
the best thing to do is leave it unplugged for a day and then unplug it when not in use , this will at least extend the life of the router
it will end up needing repair to the comunications circut eventually or just buying a new one may just be cheaper then trying to get it fixed
electech
Oct 30, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin router F5D9230-4 connection issues
First thing to do here is to reset the router, Press and hold the reset button for 15 seconds while the power is ON then after that unplug/replug the power for 5 seconds then run again the setup CD and if the router is still working after the reset it should be configure by the setup CD, if not I will advice you to contact Belkin tech support so they can further check if the router is bad already and if its still under warranty they can replace it....
Hope that helps..........
Sep 19, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
70 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
