Question about Sharp AR-153E Copier
Narrow streak down page
Using the Sharp AR-153e both as copier and printer, each page has a narrow streak down the complete page -- always in the same place on the page. I have followed manual instructions for cleaning the transfer charger and that did not help. The problem developed right after I changed the toner cartridge, but I have done this many other times with no problem.
I agree to look at the drum. It is most likely culprit. I changed my drum and still had the streak and find it is the orangish fuser roller has deteriorated and is picking up toner and mixing with little rubber bits and streaking. Take a look at the orangish roller under the jam-clearing teeth behind the door on the right side of the machine.
Posted on Apr 19, 2009
  • Sharp Master
  • 2,794 Answers
Take a look at the drum on you copier by opening up the right door. Do you see a line on the green drum? If so, your drum should be replaced.
Posted on Sep 15, 2008
How to clean my sharp ar153 copier? it produces thin black line
Is this thin line being produce when you send the original thur the document feeder?
Jul 02, 2014 | Sharp AR-153E Toner Cartridge AR153E...
How to take out the thin line comimg from my sharp ar153 copier machine
Try cleaning the slit glass. Thin strip of glass under the feeder.
clean it really well with some rubbing alcohol the line should go away.
test by making a copy off of the glass platen.
if you have a line when copying from the big glass you need some maintenance, probably a new drum/blade combo.
Skelton Business Equipment Houston Copiers
Go to the following site. Select your Product (Photocopier AR-153E) and Operating System (Win7) and download Drivers
Hope this helps.
Nov 12, 2010 | Sharp AR-153E Copier
Code L1 on a sharp AR-153E digital copier. Any help out there please?
L1 code means problem with scanner unit. cheque to see if scanner is locked if not , lube rails and ck scanner motor.
Apr 05, 2010 | Sharp AR-153E Copier
Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
Mar 26, 2010 | Sharp Office Equipment & Supplies
Driver of Sharp AR-153e
you can download them from
Jan 05, 2009 | Sharp AR-153E Copier
How do u reset the Sharp copier AR-153E? wat buttons do u push?
For error codes:
You enter simulation by pressing #,interrupt,c,interrupt in sequence display goes off, then no. 14 then start key.
Hope that helps...
Jul 14, 2008 | Sharp AR-153E Copier
Sharp AR-153E Copier Logo
87 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
