Question about Onkyo TX-SR506 Receiver
TX-SR506 Bi-Amping
My rear speakers no longer work under the "Normal Setting", unless Bi-Amping is selected, which is fine unless I want to engage my Zone 2, which does not work simultanously with Bi-amping.
How do I get my rear surround speakers to work again on the "Normal" setting?
thanks for the guidance!
    Scholar:
  • 144 Answers
If you select bi-amping the device will use a second amp for your rear speakers, this indicates that in your setup menu you probably have deleted the rears (set to None). Try to find the settings for your rear speaker in your setupmenu and see if they are selected in normal operation.
If all fails, see if you can reset teh device back to factory settings, sometimes software can get confused after using for a while. Resetting should than fix most problems.
You can also check and see if there is maybe a software update available for your device, loading and installing is explained in either the file or on manufacturers site.
Posted on Apr 17, 2009
Hi i have 4 binding posts im tryin to plug 2 av recivers into them but only the LF works not the HF can you help k
what speakers and why 2 receivers? Usually 4 posts are there for bi-amping and in normal use there is a strap combining the 2 reds and another for the 2 blacks
Aug 31, 2015 | Audio Players & Recorders
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
What technical requirements do alternative speakers for my newly purchased stereo unit have to fulfill?
Original speaker suppled with unit set up & matched, setting up your own speakers is a MINEFIELD. Best of luck.
Mar 07, 2015 | Audio Players & Recorders
I have Xavian xn125 speakers. How do I connect them in a bi-wired or bi-amp
Bi-wiring basically works wtih one amp. You need a crossover network and a signal doubler to use two amps (bi-amping). There are many diffent ways to bi-amp (horizontal, vertical,...) This link: - -http://www.soundstage.com/synergize/synergize031998.htm-- explains them all. Bi amping is usually not worth the extra price and complexity when used on smaller speakers.
May 13, 2014 | Audio Players & Recorders
It can be possible to bi-amp a pair of Klipsch RB-81 with this receiver for stereo listening, and if yes, how...
Bi-amping indicated that you have two amps, one for the tweeters, adn another for the woofer, in a two way system. If you don't have two seperate amps, you can use the speaker A & B outputs to run seperate speaker llines to each set of speaker inputs, but that will not be true bi-amping. Another alternative is to use jumpers to connect the speaker inputs together, this not needing seperate amps. Here's a link to the owner's manual:
http://www.manualslib.com/manual/359882/Klipsch-Reference-Series-Rb-41-Ii.html#product-Reference%20Series%20RB-81%20II
Oct 14, 2013 | Sony STR-DH510 5.1 Channels Receiver
What is the best configuration for wiring the Tanny MX3 speakers? i note they can be split at the back??
In audio, beauty is in the ear of the beholder.
If you're NOT bi-amping or bi-wiring them, leave the jumpers on.
Unless you were already stating with junk for electronics there is not a lot of evidence that either of those schemes would result in anything audibly superior, but they WILL cost more due to the expense for extra amplifier channels and boutique speaker wire.
Google it.
Apr 22, 2011 | Tannoy Mercury MX3-M System
I have an onkyo tx-sr506 and the system shuts off as I turn up the volume. It doesn't get very loud (barely audible) before shutting off.
Check speakers for distorted or dead drivers . Disconnect and repair. receiver will blown if not disconnected.
Mar 15, 2010 | Onkyo TX-SR506 Receiver
How do i bi amp sx 1250 to get both channels of each side to work together
you are actually not bi-amping the unit, you are bridging the amp. this really only works as long as all channels produce equal power. next the bad news is that typically home stereo amps are not wired internally to bridge channels.
bi-amping a speaker refers to connecting on channel to the highs and on channel to the lows. the receiver would need to be be able to process the outputs via a crossover network to split the frequency range in half so the appropriate frequencies went to the correct speaker.
Sep 21, 2009 | Sunfire Theater Grand Amplifier
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
Low Volume regardless of input
Front L/R and Surr back L/R are the termianls used for BI-amping
Check page 27 of the manaul
http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
you can find it here
Dec 24, 2008 | Onkyo TX-NR905 Receiver
Onkyo TX-SR506 Receiver Logo
415 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
