Question about Coleman Powermate Premium Plus 6250W Portable Generator
Coleman 6250 Not Starting
Hey Folks,
Just read much of the GREAT news for us slobs that bought this piece of **** from Home Deeps. I as well have never used mine and went to start it this weekend to check it, and guess what? It didnt start.
I did start it once about 18 months ago when I bought it just to test it and make sure all was ok. It tested then ok, but it was never used. Just ran it for 10-15 minutes and assumed all was good.
I did leave some fuel in it and after 2 hours of pulling thispast Saturday, it refused to start. I managed to fray the pull cord pretty badly too. I removed the old fuel and it was brown like shellac. though there was only about 1-1/2 cups in there. I drained it, and added some fresh gas. I then removed the fuel cup where the floater is and emptied that. That was a bit thicker and cloudy.
Problem #1, when I removed the fuel cup I found a little sprin in the bottom. Any idea where that is supposed to go?
As for the generator itself, I have no idea whaere to go or what to do with it should it not work. I guess I will attempt to return it to HD or at least got here for assistance as suggested. In the meantime, any advice on that screw, or what else I could try to get this MF started?
Thanks,
LR
  • broxstr Oct 13, 2008
    Will start and sputter for a few seconds then dies. I took off the bowl and behold a 1/2 in piece of metal with a thin wirs ie sitting in the bowl. I am guessing that his is the spring. Where does it go? Hopefully when this is placed where it belong that the generator will run.On the side, this is not my generator but my mother-in-laws thank goodness she never needed it.
  • john2363 Apr 15, 2009
    I have the same problem. I have cleaned the fuel ports and the flywheel, changed the gas and changed the plug. It's still not starting.....Why did you have to take the gas tank off???
I had the same issue, I had not been able to start my generator for the last two years. Today I finally fixed it thanks to what I read here. The solution was taking the air intake apart and cleaning the hole in the fuel cup under the carb with a thin wire. After that it started! I am somewhat mechanically inclined but have never attempted to fix an engine- so if I can do it so can you: Start by removing the gas tank (I had to cut the fuel line to remove it from the shutoff valve). Then take off air intake cover and choke lever and unscrew the metal cup underneath, its easier if you stand the generator on the side. There is a float with a little spring underneath inside. There is a little hole in the middle that was completely clogged on mine. good luck!
Posted on Jan 24, 2009
I fixed it!!! The fuel intake in the fuel cup was completely clogged with gook from old gasoline. Took the fuel cup and float valve apart. Unclogged the openings; sprayed some carburetor cleaner down into the carburetor; closed the choke; the damn thing started on the first pull!!! I spent 3 hours the week before and not even a sputter. The damn thing was fuel starved. Glad I know now.
Posted on Sep 24, 2008
    Problem Solver:
  • 18 Answers
The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clen the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Posted on Sep 19, 2008
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
A Coleman Powermate 6250 with a Briggs and Stratton engine new won't crack. Got gas to crab and motor full of oil. Spray starting fluid in it it until it's gone. Why wouldn't it start? ??
If its new, SOME generators will not start unless at least 3/4 full of gas. Spark plugs secured all the way in? Gas switch on? Pull the choke? NO MORE starting fluid, Bad Louie, BAD! some of the suggestions i posted above may help :) but, no more starting fluid.
Jun 29, 2016 | Coleman Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
How do i excite my 6250 powermate and where can i buy parts. Runs great but no power at all. Thanks John
One quick way to "excite" the field is to plug an electric drill into the outlet of the running generator. Engage the trigger on your drill and spin the chuck backwards. DO NOT HAVE YOUR FINGERS WRAPPED AROUND THE CHUCK WHEN DOING THIS. IF IT WORKS (not 100%) THE DRILL WILL START UP!!! Coleman was bought out by Pramac, you can find there webpage here.
Hope this helps.
Feb 22, 2011 | Coleman Powermate Premium Plus 6250W...
We just bought a coleman powermate 5,000-6250 gen and it runs great but will not produce electricity. i hooked a 75 watt bulb up to each plug in and it would just barely come on the fade out. but would...
Your generator produces proper voltage and 60 cycles at 3600 rpm. Use meter to adjust voltage/engine rpm. If after adjusting rpm setting and gen. does not have proper power, remove cover to generator and examine brushes and commutator rings for wear and voltage regulator/rectifier for burned components swolen or leaking capacitor and replace parts as necessary. Parts are available www.jackssmallengine.com Good luck
Sep 09, 2010 | Coleman Powermate Powermate 5000W...
Coleman 6250 Generator won't turn over
try removing the air filter and try starting if it dirty or to oily , no vacuum is created to pull the fuel into the carb
Jul 30, 2009 | Electrical Supplies
Coleman Powermate Premium Plus 6250W Portable Generator Logo
399 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
