Question about Sony Cyber-Shot DSC-S40 Digital Camera
Camera shuts off
When I can actually get my camera to turn on in "View Data" mode and switch to "Photo" mode, my camera shuts off. I replaced the batteries but I am still having the problem. Is it time to replace it?
  • Anonymous Sep 29, 2008
    Exactly the same problem. A couple of folks on different forums have suggested changing the batteries.
  • Anonymous Jan 02, 2009
    I have the same problem, I have an older version of the sony cybershot, but it is still an amazing camera. The only problem is that when I try to turn it to take picture, or recording the camera shuts off. It also sometimes turns off when i'm looking at pictures. I tried replacing the batteries, but it didn't help.
I had the same problem a few times. Try to flip the screen then press mode it will take you back to mode, instead taking photos.
Posted on Oct 10, 2008
  • 48 Answers
Check to see if the lens housing fully extents when you power up? that is a common problem.
Posted on Sep 25, 2008
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Hi, I have a Canon IXUS 95IS camera.. For some reason, when I attempt to take a photo, the LCD screen isn't displaying what is actually in view? In movie mode it comes up on the screen but when i flick it...
Ah yes! you have pressed the display button. Turn the camera on and you see the icons in the display, look for the Disp button and press it, the display will cycle through its modes icons, black, image and icons.
Jan 22, 2010 | Cameras
My finepx 2650 works in view mode but not video or
View mode uses considerably less power than zoom, focus, or photo modes. Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera, and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Dec 06, 2009 | Fuji FinePix 2650 Digital Camera
My canon powershot sd 600 will not switch between photo, video and view mode correctly
Had same problem and just fixed it! I just turned it off, took the battery AND card out for a few minutes and then making sure I had it switched to still mode, put the card and battery back in and turned it on. Working fine again. I suspect it actually does a 'reset' this way so what seemed to be a mechanical issue was definitely a software one ...
Sep 19, 2009 | Canon PowerShot SD600 Digital Camera
The camera switches itself off in photoshot mode,
Most camera have a standby mode to them, if they are on long enough they will shut off, to save your battery. In the menu somewhere there should be a option to turn that off or make it longer,
Aug 10, 2009 | Sony Cameras
Cannot view pictures taken when battery dies while shooting
I\'m surprised; I\'d expect your camera to have an effective and safe auto shutdown process in the event of a low battery.
It\'s possible that the sudden shutdown has ocurred during a write to your media card, this can cause file system and data corruption.
I\'m not familiar with the camera you are using but if you are satisfied you have followed any advice present in the camera manual regarding the situation, it\'s worth trying a third party data recovery application designed specifically for salvaging image data from corrupt media.
There are an abundance of utilities that attempt toserve the purpose, some are freeware, others are shareware or completely commercial.
A brief list (links) -
www.photo-freeware.net/digital-photo-recovery.php
http://www.flashcarddatarecovery.org/flashcarddatarecovery/dig-cam.html
Please reply if you have any questions.
May 29, 2009 | Olympus Stylus 820 Digital Camera
Battery won't charge on Kodak Easyshare V550
I don't think its the battery. My just did this this week..If I slide the Favorites switch up (switch by hand strap mounting hole) I can view the pictures in it, but it won't use in photo mode, Lens won't extend, and it shuts off?
Jul 08, 2008 | Kodak EasyShare V550 Digital Camera
A345 stuck in movie mode
you need to open the camera caseing a small amount. As you put the case back make sure the switch is in the movie position so it will engage the switch inside on the circuit board. Looks like the switch has been knocked off the control inside.If you have been moveing the switch back and forward you may have broken it.
Dec 27, 2006 | Fuji FinePix A345 Digital Camera
Stuck on change batteries
it seems that the camera section is haveing troube, may be in the lense movement or initilizing system. if the camera does not initilizes while swithcing on it turns itself off by giving low battery warning.
Nov 01, 2006 | Canon PowerShot A520 Digital Camera
Epson 3100Z battery life/power consumption
I have only had my 3100Z for about 3 months but I have found the battery life outstanding. I have the NI-MH batteries and haven't actually counted the number of pictures I take between chargings but it seems as if it is 200 or more. I also have many menu changes, view the photos in the camera and leave it on between shots. I also have sleep set for 30 seconds. I have actually never run the batteries down but recharged them twice in anticipation of needing plenty of power when I planned to take a lot of pictures. I'm guessing that you might have some faulty batteries.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
