Question about Canon Office Equipment & Supplies
I need The MF3240 Image Class Installation - Canon Office Equipment & Supplies
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
System error e100
m/c on go additional key then printer then printer reset then yes then power cycle hope problem was solved
Jan 25, 2014 | Canon imageCLASS Office Equipment &...
I cannot re install the toner cartridge in my Canon Image Class mf 3240
Possible the toner is got damaged while removing it with the printer and replace it with the new one.
Jan 01, 2013 | Canon imageCLASS MF3240 All-In-One Laser...
I have an imageclass mf3240, it intermittently prints out wrinkled pages. I would like to see if it is repairable, i did only pay $200 3 years ago so if it is cheaper/easier to just buy a new one I will. I...
Hello Lea! Welcome to FixYa!
If your printer prints wrinkled pages then first of all it may be because of paper jam or paper tray, their may be a small sheet of paper remain inside causing problem or the paper tray is not properly inserted, So check there must not be any piece of paper or if paper tray is not properly inserted, Insert it correctly.
If problem is still there then this problem is usually caused by the Fuser assembly or Tension Roller of the printer. You need to change the tension roller of the printer and if need then change the Fuser Assembly. My advise is as it is technical hardware problem so you must consult with Canon Authorized Center and they will replace the roller of the printer and if there will be need they will change the Fuser Assembly of your Canon image Class MF3240 printer
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Mar 03, 2012 | Canon imageCLASS MF3240 All-In-One Laser...
I can't install MF3240 into my window7. What can I do?
Did you download and install the drivers from here?
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/black_white_laser_multifunction/imageclass_mf3240#DriversAndSoftware
Try to turn the printer off, then go to: start menu --> devices and printers --> right click the printer --> remove device. Then install the driver. After the driver installation is completed, turn on the printer.
Feb 28, 2011 | Canon imageCLASS MF3240 All-In-One Laser...
I bought a new Canon image clas MF3240. I installed the software but it does not print. How do I print?
Make sure the software is installed correctly. Add your new printer on your hardware in computer to make them paired perfectly.
Jan 05, 2011 | Canon imageCLASS MF3240 All-In-One Laser...
Paper jam
Visit to the given link for solution....
http://support-sg.canon-asia.com/contents/SG/EN/8000572201.html
Hope this has helped you... Thanks...
Jul 09, 2010 | Canon imageCLASS MF3240 All-In-One Laser...
We have a Canon Image Class MF3240 Copier/Fax/printer/scanner. We are receiving error A4-load proper paper. We are loading with 8 1/2 by 11 paper. What is this error telling me?
The problem is on the computer, not on the printer.
"A4" is a paper size, just like "Letter" and "Legal".
You probably have your software application, such as Excel, Word, etc., set to paper size = A4.
Do this in your program on the computer:
[File]
[Page Setup]
[Size] "8 1/2 x 11"
... and print your document again.
Mar 19, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon axis 1650
Yes it is compatible. Infact it is compatible with almost all the printers in the image class series in my knowledge upto MF5750
Jul 13, 2008 | Axis Communications 1650 Print Server
78 people viewed this question
old marine
old marine
