Question about Frigidaire ATF6000ES Front Load Washer
Washing machine leaking
There is water leaking from under the machine. My husband is very handy and able to fix most anything. He is wondering if these machines are prone to leak from one certain area, and if so, what area? An 'O' ring, washer, broken hose, etc.
Thanks for any help you can offer.
  • mistified563 Sep 21, 2008
    my washer also leaks, but i have found that it leaks from the detergent dispenser. any solutions????
  • Anonymous Sep 22, 2008
    I have the same problem.   Who can i call.
They are not any more prone to leak than any other brand of front loader. He needs to take the bottom cover off and look for the source with a flashlight while the machine runs through a cycle. It could be something simple like a drain or fill hose or something much more difficult like the tub gasket. He will know that it is a tub gasket the leak originates where the two sections of the drum are fastened together.
Posted on Sep 21, 2008
My whirlpool just started leaking from the bottom of machine onto the floor. This happens when the machine is OFF and no clothes in machine. Is it a switch
The drain hose has to be higher than the water level at its highest point. IF there is water coming into the machine when it is not running then you may have a bad water inlet valve. They develop leaks like any faucet or valve. It could be some other things too, like the voltage to the valves is not completely cutting off. There is also some water that stays in those machines because it cannot all be pumped out. What is the model number?
Oct 29, 2017 | Washing Machines
After the clothes finish completely the water is leaking from the bottom of the washing machine
Do not but Do not under any circumstances continue using a leaking machine.
HighVoltage +Water=Electrocution
Get a Techo to check it out and survive to tell the tale.
Oct 24, 2009 | Roper RAS8445KQ Top Load Washer
I cleaned out the screens on the water feed, unplugged the machine for 10 or more mins., and it still flashes "ie" after numerous attempts with the spin cycle. The last expert I asked said "to turn off,...
I purchased an LG front loader washer last year in October, Luckily I purchased the extended warrenty. I had to have a repair man come out as I was stumped too. I had washed some rugs in there and it plugged up the pump. The repair man told my husband that the inlet is very small and there are lots of things that could plug the pumps up. If you are handy could tackle this but I think it is best to call someone. My husband is handy at fixing just about anything and he told me to take my rugs to the laudry mat. :(
Jul 19, 2009 | LG WM1814CW Front Load Washer
LG Tromm WM0642HW washer leaking water!
I have the same problem - just a small amount of water leaking out from under the machine. I removed the top cover and found one of the water lines rubs on the vent tube and has wore completely through. Should be an easy fix, as the line runs from the #2 spigot on the water inlet to the detergent box - both connections are right on top.
Nov 02, 2008 | Washing Machines
I have a washing machine that is about 2 1/2 years old when i started a load of wash last night water started leaking out from under it. checked the hoses and there doesnt appear to be a leak in them. any...
Depends how handy and ambitious you want to be. :) Easiest thing to do is run another load with a flashlight handy. When you start to see water try to find where it is coming from. Make sure you are not overloading the machine with soap.
Apr 28, 2008 | Washing Machines
Gasket around the door
Jan 30, 2008 | LG WM-1832C Front Load Washer
Maytag Neptune Leaking Water
pull the frount panael at the bottom and look there early model neptunes would leak around the door seal they made a kit to fix them but i dont know how old yours is so i cant tell you if thats it check the obvious hoses etc your drain pipe could be cloged the one your drain hose goes down in and just barley running over when the washer drains tell your husband to fill it then then switch to drain and listen to the pipe will sound like a bottle filling up when it drains or he will see it running over while it fills look under the bottom panel for leaks hope that helps
Dec 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
90 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
