Question about Amana Washing Machines
Amana Washer I have an Amana washer Model # LW9203W2, Serial R9702011805 MFG No. PLW9203W2B My Unbalance light was on and the audible beep was sounding , I opened up the washer and the water was full , with unbalance light flashing, Fixed the load and attempted to clear the unbalance , but the machine just Flashes the minutes amount in soil level area,Machine is still full of water and im unable to get it to work. Thanks in advance Tommy
jsrock516
  • 5911 Answers
SOURCE: unbalance
You problem may a simple leveling issue. Check your machine front to back and side to side to ensure it properly level. Also, most top-loaders have "self-leveling" feet on the rear legs. If you walk up to your washer and it looks like the back is sitting lower than the front, you may only have to follow a few simple steps to re-level it. If your machine is equipped with this type of leveling system all you have to do is to lift the rear legs of the floor about two-inches by rocking the machine (empty of water, of course) towards you: 1. Lift the lid. 2. Place one hand under the rim of the front casing (not the wash tub). 3. Place your foot at the center of the front base to keep it from sliding. 4. Pull towards you to lift the back feet off the floor. 5. You should hear clicking noises as the feet re-level. 6. Slowly lower machine back to the floor. This should take care of most leveling problems that cause your machine to vibrate and shake during the spin cycle. These legs periodically become unlevel due to vibration and need to checked from time to time. I hope this may help you.
Posted on Apr 15, 2007
SolutionGuy
  • 331 Answers
SOURCE: washer unbalanced on final spin, cannot stop the unbalance
Hi Sparky,
The reason it's out of balance is because the skate plate shoes are worn out and need to be replaced. You'll have to access the washer in order to do this. There's a video available that shows how to do it.
After you have opened up the washer you'll see that the tub is sitting on a three legged pedestal. The shoes are in between the skate plate and the top of the pedestal. Here's a picture (and part number) to illustrate...
Do one shoe at a time by lifting the skate plate off of the pedestal about an inch or so and wedging it there (I use a hammer handle as a wedge). The shoes simply snap into place, so the old ones will have to be snapped out of place first. Use another hammer and tap the shoes out of their sockets from underneath.
NOTE! ---> When you place the new shoe into its' place DO NOT try to snap it in!!! (if you do, you'll break it) Just let it rest in it's place for now. Remove your wedge and allow the full weight of the tub to sit on it. Then move on to the next shoe and repeat.
After all 3 shoes have been replaced it's time to snap them in completely. Do this from the top of the tub. Using your body weight, press down on the tub from above on all three corners (where the shoes are located). This will apply even pressure to the top of the shoe and keep it from breaking. You should have all 3 snapped in now. Use a flashlight and look underneath to verify (you should see the tabs of the shoes poking all the way through the pedestal).
Now all that's left is to rebuild the washer cabinet and start some laundry!
SG
p.s. I know it sounds like a lot of work, but this job can be done easily within an hour and the parts only cost ~$12.00!
Posted on Apr 01, 2009
SOURCE: washing machine keeps getting unbalance
What you should try if I understand your question correctly is to evenly place the clothing through out the machine on all sides. Hope that helps, John
Posted on Jun 08, 2009
SOURCE: "Continous Unbalance"
we had the same problem. had a tech come out, he said it was the control board/motor. Never heard back from him with a quote to finish the repair (but he never billed me for the visit either, so hesitant to call him back!!), so used the 'diagnosis' and bought it on-line, $175. Husband installed, did NOT fix the problem. did more investigating on-line, decided to spend under $20 (eBay) on this: Maytag Washer Unbalance Switch #22003302 - cheaper than calling a repair person, so worth a try. Husband installed, FIXED!
Posted on Jun 17, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: Unbalance Issue with my washer model FAV6800AWW.
Hi 2pleach
If you are taken dC/uC errors I think you have to drop the clutch out again and see if you can clean and Re-Lube the One-Way Roller clutches/bearing. I wonder if you have a slight tub seal leak causing this issue to reoccur. Did you follow my clutch maintenance/replacement post Clutch repair post on this site? As you know I’m a DIY’er/owner as you. You did the right troubleshooting with the TDS check.
I have posted solutions under dh1200s and FAV6800AWDIY. I feel I have 50+ machine saves $1k original cost I think between this site, FIXITNOW.COM, APPLIANCEJUNK.com Appliance repairparts.com forum. I go by dh1200s on those forums. The bulk of this FAV6800AW/FAV9800A machine owners flock to this forum…..I should get some consulting $fee$....:) but I do it for nada just trying help owners like myself not junk a $1000 machine.
Regarding the struts see this post. I feel if you are going to chime in on a fix you should know the subject matter. If the tub sets level and returns to normal after the TDS checks you are good to go…..not rocket science just common sense and good old fashion troubleshooting. A lost art among some repair folks or they never had it to begin with.
You are a very savvy DIY’er let’s drop the clutch out again. Please look at this post I show how to test if the One-Way Roller clutches are not locking up in the CCWSpin cycle direction. Don’t get distracted with misinformed info about the front struts.
I can give you phone support if necessary just let me know what I can do to help…. I push no snake oil fixes….:)…Rich I go by *D*i*c*k* but this BS board blanks it out as a nasty .
Posted on Jan 03, 2010
I have an amana front load washer model #nfw7300wwo2 and the power will come on and the add garment light and the door will lock but the washing process does not happen and 5 mins after it begins to beep,...
Sounds like a job for an appliance repairman. The beeps are probably a code for what's wrong and since most of these are solid state, meaning they have circuit boards you need someone trained to identify and replace the proper board
Jan 03, 2015 | Amana NFW7300WW 27" Front-Load Washer with...
Ltf2140
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 29, 2012 | Frigidaire GLTF2940ES Front Load Washer
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Nov 28, 2010 | Amana Washing Machines
Model# FAV6800AWW Serial#16470128GL I have the neptune top loader. I gets down to 8 minutes, then goes back up to 11 minutes, won't complete the cycle, but gives the UC code. I have replaced the struts...
Thank you for Model Number and S/N the first two digits are your Serial Number is your Series number.
Yea that left side bleach dispenser is hard on the TDS the Left Hand Lid Lock also.
Is the washer banging around with the uC unbalance error?
If so see my Clutch Fix post I feel you have a possible issue with slipping One-Way Roller Clutches bearing in the Clutch Pulley.
With that much corrosion I’m concerned about the TDS 3 pin plug. But lets try the TDS check first because of the severe strut corrosion.
It’s in the Service Manual but I’ll type it out. Let’s make sure the TDS is signaling the Control Board correctly with this thru the lid test.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you get these results then I feel your TDS is working as designed and signaling the Control Board correctly. What are your results?
I feel it is now time to remove the Clutch Pulley. Follow my post including the test to insure the One-Way Roller Clutches bearings are locking up solid in the CCW direction the Spin Cycle direction.
I hope you can extend the service life of your machine with clutch maintenance.
Let me know if I can help………Rich
Apr 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Age of Amana washer
Hi there Sue. Go to this Amana link and input your data. They will tell you the age.
http://amana.custhelp.com/app/answers/list
Jul 31, 2009 | Washing Machines
TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
Apr 30, 2009 | Amana ALW480DA Top Load Washer
Amana control panel sparks
your panel shorted out
replace control panel and wire harness is my recommendation
Although depending on age, these two parts are quite costly the panel alone is 272$ retail
if you decide to buy it you can call amana 866-616-2664
to purchase them, or local dealer normally can sell you the parts
but with a major short like that id recommend replace, if you buy parts bring model, serial, and MFG manufacturing number starting PALW
May 02, 2008 | Washing Machines
Washing Machines Logo
65 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Terry Schneider
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
