Coleman rv ac
The unit is making so much noise when the compressor is on it is giving me a headache
  • Anonymous Oct 30, 2008
    the a/c has just been installed (so brand new!) and when the compressor kicks in? the noise is beyond sleeping through. the rest of the time it is relatively quiet.
  • Anonymous Mar 29, 2014
    need to know the watts required for a coleman rv ac unit 7300-713
  • 126 Answers
AGE CAN BE A CAUSE OF A NOISEY UNIY.BUT IF THATS NIT THE CASE YOU NEED TO CHECK IF THE UNIT IS STILL INSTALLED SERCURLEY AND THE BOLTS ARE TIGHT YOU MIGHT NEED TO INSTALL RUBBER SHOCK PADS TO REDUCE THE NOISE IF IT DOESNT GO AWAY.GOODLUCK.MOHAMED
Posted on Sep 16, 2008
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
I need to find the proper charge for my coleman rv ac i do hv ac work so i hav guages but im not rel experienced and i dont hav the charts for this unit. can u help
If you don't have the exact charge by weight, just charge up to approx 68 psig suction, it should be at least 80 degrees ambient outside and warm in the rv when you do this, put an ampmeter on compressor and go no higher than the full load amps on nameplate. 68 psig will give you about 40 degree evaporator temp
Jul 17, 2011 | Heating & Cooling
Air conditioner blows the breaker when starting up
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
Coleman RV Roof Type 110v
GO TO rvcomfort.com
Jul 25, 2010 | Coleman Heating & Cooling
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Changing filter on coleman AC located under RV. 2005 Dolphin . I don't know the location of the filter on my Coleman RV AC unit located under the RV. Also, I would like a maintenance and operation manual...
GO TO rvcomfort.com
Aug 22, 2009 | Heating & Cooling
I would like to run a coleman rv roof air conditioner Mod # 6727-736 on the bench before installing on the Rv. It is a used unit. The plugin has 6 wires. I wont to see if the compressor is still...
GO TO
www.rvcomfort.com
May 09, 2009 | Heating & Cooling
Coleman roof a/c units compressor not coming on
GO TO
www.rvcomfort.com
Feb 01, 2009 | Dometic Rooftop RV Air Conditioner
Coleman (RVP) 7000 AC unit compressor problem
I had a problem with my coleman mach 3 AC, we were at an RV park up at lake shasta CA and the fan would stay on but the compressor would come on for a few seconds and then trip off. It was the motor overload relay on the compressor that was tripping. the RV park was old and apparently the wiring to the panelboard at the RV park was too small, when you are drawing a lot of current there was too much voltage drop across their line, to make up for this the motor tries to draw more current and heats up the motor overload and it trips off. I solved this problem by buying an autoformer from Camping World, it senses a voltage drop and automatically boosts the voltage.
I am now having a seperate problem, the compressor is either locked up or has too much back pressure and trips off the service breaker when trying to start. The only solution I can see with my current problem is to replace the entire unit.
Oct 07, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
139 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
