Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge 1
The water and the ice dispencer not working on the door but still makes ice and dripes water nothing else
  • 120 Answers
Is looks like you need to trouble shoot *********** board is this unit has one i can see if i can fix it for you bu i need more info how old is it is it side by side let me know call 562-688-3627
Posted on Oct 12, 2008
Ge will not dispence water or ice and the light on control panel blinking green cannot change from ice to water.
at the bottom of the door is a grill remove and check the wireing plug for corrosion if it has a lot of green around it you will have to hard wire it wire for wire has bad connection .
Sep 21, 2014 | GE Refrigerators
I have a GE fridge and the ice/water dispencer failed
#1 Please check WATER SUPPLY!
AutoShutoff Feature built into most models is an electronic lockout to the components in freezer compartment should water pressure fail or slow down enough not to trigger float sensor.
Option 2, you have an ICE JAMB inside the door sleeve, or the overflow freeze-thaw switch is stuck, a plastic tab that rests against the ice to tell refrigerator ice is now frozen. Somewtimes it freezes up & just needs a flick of a finger to reset the cycle. You will also have to manually trigger this if water is unavailable, once supply pressure returns.
CULPRITS: Inline or Internal water pre-filter, Tee connectors off lower level supply, may be corroded, tap pipe with light hammer gently if suspect. Pull out fride, turn off water at supply cut-off., remove line to fridge & place in large bottle. Go kick on supply, tap pipe, count to 5 shut off & check bottle for flow. If this does not solve problem, then a circuit board or membrane connection from door to case may be defective.
Apr 18, 2010 | Refrigerators
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Fridge not cooling enough
Check compressor if it is working fine then check temperature thermostat. If they both are good then either your fridge has ran out of gas or the doors are not closing properly.
Nov 09, 2017 | Refrigerators
GE GSH22JSRE Refrigerator Ice / Water Dispensing Issue
I have the same issues as above, ice maker makes ice but will not dispence or give water,
when I push the lever to get anything the lights go out and the fans slows or stops until I let go of lever.
Side by side GE : Model # GSH25KGRE WW / Serial # MG278521
has anybody else had this issue with this model?
Feb 02, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker problem, side by side refrigerator
ice in ice bin sort of melts and sticks together and wont dispence out the door . it is a G E
Jul 29, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
65 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
