Question about Samsung DVD-HR735 DVD Recorder/HDD Recorder
Samsung DVD HR753
I just bought this equipment for the purpose of transfering VHS tapes onto DVD format. I hooked it up as per the diagram and it plays DVDs just fine but it will not record.
The VHS player is hooked up to the HR753 and it plays the VHS tape on the proper AV channel (thus telling me that the HR753 is getting a signal) but as soon as you put in a DVD-R it over-rides the VHS signal, the screen goes blank and it tells you that there is no signal to record. Of course, the first day that I hooked it up the VHS signal continued to show on the screen even after the DVD-R was put into the machine but it gave me a message saying that the TV was not compatible. The next day it started with the first statement even though nothing had been changed!
Now, I am an American who has just moved to Norway so of course the manual is mostly unreadable to me. I thought that maybe I need to record the VHS signal onto the hard drive (HDD) first and then record it onto the DVD afterwards but I could not get any response from the hard drive either.
In short, eveything is hooked up correctly to my knowledge. The DVD player works just fine but sending the VHS signal to be recorded on disc or sent to the hard-drive is unsuccessful. When a DVD-R is placed into the drive there is no indication that the automatic formating has been performed, in fact there is no indication that the machine even realizes that there is a disc in the drive. Pressing the record button receives no (zero, zilch, none) indication or response from the machine whatsoever.
My thoughts on possible solutions:
A: Something really simple that I am not doing in accordance to the instructions enclosed in my unreadable manual (due to language differences). Where do I get an operations manual?
B: DVD-R is not a usable format? I would think that it would tell me on-screen if that was the case but maybe not?
C: The machine is just not working properly and needs to be serviced?
D: Other.
5 Suggested Answers
  • 119 Answers
SOURCE: recording tv from a vhs player
sound like you have a dirty video head, try cleaning the head with some isopropyl alchol. if it does not fix your problem, then you will have a bad video head. good luck
Posted on Feb 15, 2007
  • 3 Answers
SOURCE: Samsung DVD-V$357 recorded dvds won't play on other machines
Did you finalize the disk? If not, this should solve your problem. When the disk is finalized you should be able to play it on your computer if you can play other DVDs on it. Some other DVD players can only play specific disks (i.e. DVD-R, DVD+R). This may be another problem.
pjrsop
Posted on May 01, 2008
SOURCE: Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Posted on Aug 24, 2008
  • 9 Answers
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Posted on Jan 03, 2009
How can I record home VHS videos to a DVD on my Samsung DVD-VR320 DVD Recorder/VCR?
BE CERTAIN OF THE KIND OF DVD DISKS IT SUPPORTS. My experience is that the kind of discs while you would think would not make a difference actually do make a big difference depending on the equipment you are using. I just transferred 15 vhs tapes to DVD and realized that the machine only took a few formats luckily it was the one I was using, but not all formats may be compatible. There is a difference between DVD+R and DVD-R as an example.
Jul 12, 2014 | Samsung DVD-VR320 DVD Recorder/VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Re v5500 . . . can i copy a movie from the vcr onto a dvd with this model???
You cannot transfer VHS to DVD on this model unit by itself. You can, however, connect the AV outputs of this unit (as a VCR) to the respective AV inputs of a separate DVD recorder - using yellow-white-red RCA cables - as long as the source tapes are not copy protected, and the appropriate disc formats for the DVD recorder are used.
Apr 20, 2011 | Samsung DVD-V5500 DVD Player/VCR
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
VHS tape created in France
If it was made with the French standard you will need a machine capable of playing SECAM formats. Your cheapest way to go is to locate a video transfer business which deals in tape transfer. They should have the equipment which can play the tape and record it in a format which you can use. Cost should not be that much.
hardrocko
Thanks for using FixYa
Jan 12, 2010 | TDK T 120HS VHS Tape
Dec 30, 2008 | Samsung DVD-V4600 DVD Player/VCR
Voice track not matching video track
I believe Samsung have update firmware to correct that problem, contact Samsung in your area or country
Cheers
Dec 09, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
VHS to DVD
I just bought at Best Buy the Samsung DVD Recorder & VCR. You can copy your VHS tapes right to DVD and or hook up an external source into the deck and copy them to DVD.  I find it working well but many of my tapes have tracking issues which is becoming a hurdle for myself.
Apr 22, 2008 | Samsung DVD-V4600 DVD Player/VCR
Copying vhs to dvd using samsung vr357 ??
I do not think you would have to worry about a way to disable the copy protection that is on the vhs tapes. you are not going to record over them. You are just going to transfer information to the dvd side. jh
Nov 18, 2007 | Samsung DVD-VR357
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Open Questions:
See all Samsung DVD-HR735 DVD Recorder/HDD Recorder Questions
Samsung DVD-HR735 DVD Recorder/HDD Recorder Logo
83 people viewed this question
Jerry Greenberg
Jerry Greenberg
