Question about Lexmark Office Equipment & Supplies
I have a 3500-4500 series printer. 3550 actually. I have been using #23 Black Print Cartridge. Now I cannot find this any place I have shopped. WHAT number has the BLACK ink change to. Thanks, Sylvia
    Genius:
  • 1,056 Answers
You can buy them direct from Lexmark in a couple of different ways. The buy use and throw away, $25, or the buy use and return for $20.
Just go to http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
Posted on Sep 15, 2008
Xerox 3550 toner install
Replace the print cartridge using the following instructions:
1. Release both latches on the side of the front door and open the door.
2. Pull the print cartridge out.
3. Remove the new print cartridge from its bag.
4. Slowly shake the cartridge five or six times to distribute the toner evenly inside the cartridge. It will provide maximum copies per cartridge.
Note: If toner gets on your clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
CAUTION: Do not touch the green underside of the print cartridge. Use the handle on the cartridge to avoid touching this area.
5. Hold the print cartridge by the handle and slowly insert the cartridge into the opening in the machine.
6. Tabs on the sides of the cartridge and corresponding grooves within the machine will guide the cartridge into the correct position until it locks into place completely.
7. Close the front door. Make sure that the cover is securely closed.
Nov 22, 2012 | Xerox 3550 AllInOne Laser Printer
I've already replaced the black cartridge but still my hp printer can't print in black ink... what will I do???
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Apr 09, 2011 | HP DeskJet 3550 InkJet Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
I have a brand-new black ink cartridge that is most definitely properly installed in my hp deskjet 3550 printer, but the printer simply will not print in black. Every document comes out blue and pink, and...
go to printers & faxies option open that just write clinck on printer icom properties prnter setings just select your both colores u have not setlect back
May 13, 2010 | HP DeskJet 3550 InkJet Printer
I have installed a black 23 print cartridge in my x3550 printer, and it is indicating that the cartridge is incorrect, however, this is the same cartridge that is required.
Left/Right Cartidge Incorrect - huh? The printer is saying Left Cartridge Incorrect or Right Cartridge Incorrect,
and you are sure that you inserted the correct cartridge, a #23 or #24.
A small number of #23/#24 cartridges will report as Incorrect Cartridge because
of a manufacturing issue. There is a firmware upgrade available to fix this problem, and allow
the printer to accept the cartridge.
3500-4500 Series (X3550, X4550)
3400 Series (X3430)
1400 Series (Z1420)
To apply the upgrade:
  1. Make sure the printer is turned ON and connected with a USB cable.
  2. Download and run the appropriate update program using the links above.
  3. Be careful not to disconnect or turn off your printer while it is being updated.
When the update is complete the printer should automatically restart and accept the #23/#24 cartridges.
Jun 18, 2009 | Lexmark X3550 All-In-One Printer
SLOW, SLOW PRINTING
try saving the things you want to print as a pdf file, then print them from there
Jun 01, 2009 | HP DeskJet 3550 InkJet Printer
Deskjet doesn't print real "black"
In the printer preferences, you can choose to print black or color. Check to make sure that when you print, you haven't specified color only.
Apr 30, 2009 | HP DeskJet 3550 InkJet Printer
Hp 3550 printer color cartridge printing but black not printing
Perform print head cleaning and also try to take a test page and ensure that ink is properly injected out of nozzle.
If this doesnot work take out the cartridge and clean the contact and reinsert the cartridge .
Jan 30, 2009 | HP DeskJet 3550 InkJet Printer
I want to change printing to black and white only
u have to do this remove your colour cardige then print it u will get black & white print
Jan 11, 2009 | HP DeskJet 3550 InkJet Printer
3500-4500 series lexmark
Can you make sure the number corresponds with the typewriter itself? Sometimes, the manual could be a typo/misprint.
Zabrina
Jan 20, 2008 | Lexmark Wheelwriter 3500 Typewriter
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
