SOURCE: PANASONIC DMR E85H
Yes you can.
You can get the instruction manual here:
http://service.us.panasonic.com/OPERMANPDF/DMRE85H.PDF
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Unit must get the TV guide from an analog station. If cable company goes digital you loose the data. If the station that hosted TV guide goes digital you loose the data. This unit does not have a digital ATSC tuner only analog NTSC tuner. If you are still getting analog data there are a few capacitors on the power supply under the hard drive that bulge up and cause problems. They should be replaced with higher voltage rating types.
SOURCE: Panasonic DVD player shows EXT-L in its display.
You have switched machine onto external link mode
Either press external link on remote or find it under the flap.
Has a small child been playing with the remote?
SOURCE: Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
