Question about GE JASRM24912 Remote Control
GE remote control
Did you get the codes for your GE remote control, to program for your tv?
  • 1 more comment
  • kovacdk Nov 26, 2008
  • m432medley Nov 26, 2008
    I lost the codes can you help??
  • sounds4 Jan 17, 2009
    I programmed this new device last month but it won't work now (batteries work). I can't locate the directions and codes. May I please have the steps and code for a zenith tv? Thank you.
Remote codes for GE univeral remote
Posted on Sep 18, 2008
SOURCE: In need of tv codes for ge romote control
You don't need a code. Just follow the instruction as follows:
1. Tun on TV
2. Press and hold "code search" until light stays on, then release.
3. Press TV botton
4. Press on-off repeatedly until TV turns off
5. Press enter.
That is it. It works for me.
Posted on Nov 05, 2007
  • 2712 Answers
SOURCE: Ge remote control #24921
You can find the remote control codes for different brands of devices from
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
Posted on May 05, 2008
  • 61 Answers
SOURCE: codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Posted on Dec 14, 2008
the q guy
  • 393 Answers
I found that this website should have all the codes and instructions for most remotes
Posted on May 11, 2009
SOURCE: I have a ge universal remote model #24110R need tv code
Posted on Aug 13, 2010
How do you program it to a GE universal remote
these are the codes
LG: 004 005 009 012 050 057 080 156 227 338
  • How to Program a GE Universal Remote ' Techwalla Lost your Remote? Need help programming your GE Universal Remote? Most TV's, VCR's, DVD Player's, Cable and Satellite Boxes will work with a GE universal...
  • How to Program GE Universal Remote: Quick Steps > Electronics > Home Theater > Home Media 2011-04-18 · How to Program GE Universal Remote Using the Code Search Function. If you've tried the codes listed for your device brand and are unable to get your ...
  • GE Universal Remote Codes and Instructions ' direcTutor Goto GE remote Codes. Direct Code Entry for GE remotes with 4 digit codes. 1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
  • How to Program a GE TV Remote ' Techwalla GE universal remote controls allow users to program multiple devices onto a single remote. The remote control uses codes to detect the device, and you can...
  • GE Universal Remote Quick Start Guide - YouTube Youtube
    • 3 MIN
    2013-04-18 · Video embedded · Eliminate remote clutter with GE Universal Remotes
  • How to Program a GE Universal Remote Control ' eHow > Tech > TVs > Remote Controls
    Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are ...
  • May 09, 2016 | LG "32"" inch New 2011 HD LCD TV With HD...
    GE Universal Remote Codes ' Jasco
    Make a note of which version you have and replace the batteries and cover. A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Programyour GE Universal Remote using the correct code list and instructions. ... Sometimes a code will allow limited function control (e.g. volume and channel ...
    Universal Remote Control Codes
    Codes and links for a number of universal remote controls, including Sony, RCA, ... If you have a remote for which you know the codes (or a web page that lists them) head to ... How to Program a GE Universal Remote Control .... look for your model of TV or VCR and find the online instructions that include the remote codes.
    RCA Universal Remote Control- Target Programming ...
    Jan 05, 2016 | Coby TF-TV3217 32 in. LCD TV
    I have a GE JC024 tv remote and need code for an Emerson tv
    These are the setup codes for Emerson TV, with GE remote control.
    0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
    Sep 20, 2012 | GE Remote Original Jc024 Remote Control...
    Apr 07, 2010 | Universal Remote Control GE174Universal...
    Need code 4 ge universal remote? 24911 4 ge tv
    i need my code for my tv. The brand of my tv is Magnavox. I also need the steps to program the remote because I lost my book
    Mar 30, 2010 | Jasco 24911 Remote Control
    I have a GE 24991 universal remote and a Samsung Tv. I need a list of tv codes so I can try to program it.
    The codes that GE list for the Samsung are:
    0105, 0077, 0076, 0109, 0007, 0009, 0004, 0005, 0085, 0172, 0942, 0358, 0012, 0015, 0080, 0104, 0106.
    Also, here is a link to the .pdf of all the codes for the GE 24911 and all other GE four code universal remotes...
    Code List for 4 digit Universal Remotes from the GE website. <-click here
    Oct 29, 2009 | Jasco 24911 Remote Control
    Need codes for ge universal remote
    I'm need a etec tv code to program DirecTV remote control can you help me please?
    May 17, 2009 | GE JASRM24912 Remote Control
    Universal remote
    Codes for Panasonic TV.....171,148,054,170,062,374,381,437,003,070. You can Goggle the programming info...Just ask...How do I program a GE Universal Remote... There are about 7 steps...easy if these codes work....good luck...I have a remote that none of the given codes are working........
    Nov 22, 2007 | GE JASRM24912 Remote Control
    GE JASRM24912 Remote Control Logo
    449 people viewed this question
    Top GE Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you a GE Televison and Video Expert? Answer questions, earn points and help others
