Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Won't turn on
Standbylight blinks 9 times
  • 2,071 Answers
Diagnostic code meaning;
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Hope it may help you;
    Regards,
    VOTIT
    Posted on Sep 19, 2008
    My sony the standby button blinks 11 times then 5 times then 5 times. Would the problem be the same as those that have it blink 9 or 10 times?
    if the set blinks 9 times its the G board which is the board on the far left side where the power cord plugs into. The D board is the large board in the center just to the right of the G board.
    Nov 20, 2011 | Sony KP-46WT520 46" Rear Projection...
    My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
    When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
    Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
    What is the error code?
    Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
    Standbylight and green light blink when try to turn on
    Remove the Lamp Door and then reinstall the lamp door. This resets the safety interlock switch.
    Apr 09, 2010 | Samsung 50" Slim-Depth DLP HDTV
    Problem for Sony KP-57WS520 57 in. Rear Projection HDTV-Ready... Stand by light flashing, TV will not turn on
    need to know the number of blinks as thats an error code. it should blink a series of blinks pause briefly then repeat the sequence.
    Nov 23, 2009 | Sony KP-57WS520 57" Rear Projection...
    The tv wont turn on. the red light blinks 9 times.
    There is a problem with one or two of the diodes on the G board.
    Zero Crossing Detector 9 times 9:0 or 9:1
    Probable cause • D6116 or D6301 is open (G Board)
    symptom • No picture
    I hope this helps and good luck!
    Oct 31, 2009 | Sony KP-51WS520 51" Rear Projection...
    Tv won,t come on now
    i have a kp51ws520 that i just fixed. it blinked 9 times. found out it was the g board. got it done pretty cheap . let me know if you need more info.
    Feb 05, 2009 | RCA Scenium D40W20 40" Rear Projection...
    9 blinks
    D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
    Jan 05, 2009 | Sony KP-46WT520 46" Rear Projection...
    Tv wont turn on blinks 9 times then 1 time
    I was inform that it could be a sensor (bad diode), you have to get a multimeter tester and test the diodes and if current flows from both sides then replace that diode.
    Nov 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
    9 red blinks
    Can you verify that its 9 blinks? There is no error code in that set for 9. also please verify that its a kdsr50xbr1
    Thanks
    Tim
    Jun 29, 2008 | Sony KDS-R50XBR1 50" HDTV
    Red light blinks 10 times then 9 but won't turn on.
    Can you confirm that the model number of your set is KP46WT520 as I dont want to give you the wrong information.
    Jun 24, 2008 | Sony KP-46WT520 46" Rear Projection...
    Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
    123 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
