Question about HP Office Equipment & Supplies
Iwant to change the coloured ink - HP Office Equipment & Supplies
  • 399 Answers
Just open the front door while the printer is on. the carriage will move and stand to the cartridge install position.hold the colour cartridge pust it little bit towards down till it leaves the lock and then get it ouside towards ur the new cartridge in the reverse procedure.
Posted on Sep 15, 2008
Black colour is not printing
When you print in color is does it show black ink?
Sep 23, 2010 | Office Equipment & Supplies
My printer doesn't want to print in colour. I must have changed a setting. Even after I have changed all the colour cartridges and adjust the setting it would still not print any colour. It also doesn't...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Sep 21, 2010 | Brother Office Equipment & Supplies
Printer will not print in black. Colour ink appears to be out. Should this effect it
Yes for sure If your colour ink is down there is the possibility that the print may vary in colour.As the colour ink level decreases you might have got the error to change the ink. Hence it will tend to change the printing commands. To further confirm on this you can disconnect printer, uninstall and reinstall the printer software,then connect the printer for hardware detection and installation. now do a head cleaning maintenance and a test printing. If there is still no change it will be better to replace the colour cartridge after using the menu for ink cartridge changing so as to get the ink indication correct after installation. Hope you try this out. Good day
Aug 13, 2010 | Epson Stylus C46 InkJet Printer
I have multipack ink for sx115. the blue has run out. how do i change it to go to net colour. thank you
There is no any way to change only blue colour ink. You need to change complete cartradge of this Epson printer.
Apr 13, 2010 | Office Equipment & Supplies
Printer HP Deskjet D1460 prints pink"..Instead of Black
The printed colours are an "additive" mix of the "primary" colours in your printer.
So, when the colour ink-jet cartridge is "out-of-ink" on one (or more) of its colours, the "mix" will be off, and the "wrong" colour will be the result.
Change the colour cartridge.
Before changing it, run a "deep-cleaning" cycle, using the HP Support software that was installed when you installed from the CD-ROM that came with the printer, to "clean" any/all "clogged" ink-jets -- i.e., a clog could be preventing one colour of ink from being sprayed onto the paper.
Apr 08, 2010 | HP DeskJet D1460 InkJet Printer
How to change ink cartridge ?
open the printer by lifting the lid, and the ink cartridges will auto move to where you can have access to them, ensure you have the power on, check in detail the present position, and replace the new inks colour by colour in the same position, close lid, power off the printer for 3minutes, power on again and follow the instructions on alignment, and cleaning of the new inks
Mar 31, 2010 | HP Officejet 4315 All-in-One Printer
It is printing everything with a green tint and I had not changed any settings. I have also gone out and bought two new ink cartridges thinking maybe the new one I had was defective. There is no change...
I have personally encountered similar problem in my work. There is no problem with your printer.
Sometimes when either of the inks overflow at the nozzle, it gets absorbed to an extent into another ink compartment. So that colour affected now prints another colour; the colour that has crept into its compartment, Sometimes it is serious at other times is not. If not serious, usually, after a few solid colour prints the colour affected returns to normal.
I do not know how much of a technical person you are, but I will give you the solution to returning your colours from green the right colour. Bring out your colour cartridge. Peel off the seal covering top of the ink cartridge. You will see the holes through which in is fed into it. Get a clean handkerchief, fold it and place over the top of the cartridge. Hold it over a bowl or something. Now place your mouth over the top with the handkerchief in between and blow hard. Ink will discharged at the nozzle. Clean off the ink. (At the nozzle do not rub only dab). Now press a piece of folded tissue to the nozzle firmly. It should be blotted with ink:- red, blue, yellow. If any colour is missing you may need to repeat the procedure. Once you get the three colours back, the issue is resolved.
Dec 21, 2009 | Kodak ESP 5 Printer
It doesnt let me print in black
For a quick fix, take you colour cartridges out give them a good shake and put them back in - Remeber to turn off any colour test prints the printer is set up to do.
May 11, 2009 | Office Equipment & Supplies
Printer won't recognise new colour cartridge
I got a new print head @ "staples" office supplies. It didnt cost me anything!!! Kodak had probs with the head, & gave a bunch to staples.....i changed the head, put in new inks, a calibration to run...& things printed np!!!
Apr 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Ben Johnson
