Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam washer
What does the code F35 mean?
  • Whirlpool Master
  • 8,205 Answers
F-35 is a failed analog pressure switch. A common problem these days.
I have a replacement how to video HERE
Posted on Nov 03, 2011
  • 126 Answers
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
  • dwitter Jun 30, 2011
    Before calling a repairman, check the pump strainer to see if it is clogged or has coins or a sock blocking it. The pump strainer is behind the lower front panel. The front panel comes off by removing the three torx (star type) screws located underneath the panel. The pump strainer cover is white and about 3" in diameter and unscrews by hand. Here is a link to a picture:http://neighboursappliance.com/2008/01/d...
  • ASDFjack Aug 25, 2012
    I have a Whirlpool Duet (steam model, built in 2007). Getting the ever common "sud" and "F35" error. Done all the typical research. Took top and bottom off. Everything clear. Have not taken back off and looked at the actual "air trap". But, I can blow throw the black tube that connects to the pressure sensor switch. All research seems to point to the notion/belief that my sensor is bad.
    Scholar:
  • 79 Answers
Outside the normal analog pressure sensor (APS) / hose checks...
Another cause for the F35 and SUD error could be your CCU (control unit). There are components that seem to fail over time and cause the F35 and SUD errors. You can replace those components yourself now...
See f35 error for more information.
I hope this helps and let me know if you have any more questions.
Posted on Jul 10, 2015
Replaced the $109 pressure switch for my Kenmore he3t, and sorry to report here is no change with the new pressure switch. I ran the diagnostic and it makes it through the C:00 test fine and then throws a F35 error before it gets to the C:01 test. I don't know if I'm going to have to end up building this thing part by part.
Posted on Feb 01, 2014
  • jtusmc91
    jtusmc91 Feb 01, 2014
  • Dan Webster
    Dan Webster Feb 05, 2014
    Must be something wrong with the control board.
    Genius:
  • 1,416 Answers
Hello.
The F35 alert code on your Whirlpool washing machine indicates a problem with the drainage system. This could be an easy fix, or it could require a complete replacement of the water discharge pump. Before you can determine how to correct the issue, you must complete the troubleshooting process.
Thanks.
Posted on Nov 09, 2011
3 Suggested Answers
  • 530 Answers
SOURCE: F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Posted on Jun 25, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
I have a Whirlpool Duet Washer, washer starts and then stops code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam WFW9600TW00 code F35
Kevin
Oct 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When I put a wash in, IT RUNS FOR A MINUTE AND READS SUD OR F35. THIS HAPPENS AND THE WASHER JUST SITS NOT MOVING AT ALL
Kevin
Sep 05, 2011 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Suds then f35 Whirlpool Duet 4.0 Cu. Ft. 14-Cycle Steam Washer - White
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 29, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Error code washing is delayed wil wash half the clothes
Mar 06, 2010 | Whirlpool GHW9300 Duet Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Steam washer (WFW9600TW) flashes F35 shortly after the cycle starts and then turns itself off.
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 flashing
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,141 people viewed this question
Dan Webster
Dan Webster
prem mathew
