Removed 4 screws with black plastic on the bottome. Then slowly seperate the lower housing. Lithium battery is located on the electirc diplay unit which has 3 screws. Unfortunately, the battery is soldered on and will require a shop with soldering experience to replace. I'm having the flashing 0:00 issue and my rice cooker is not working.
SOURCE: Hi I was wondering if
Have you tried scrubbing the inside (heating surface). Make sure there is no burnt on stuff on it and on the middle sensor (CENTER OF THE UNIT). I usually use a green scrubber with Comet. Also make sure that the bottom of the rice insert (outside) is clean.
