Question about LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive
CD - ROM
I have a Dell D600 and the dvd and cr rom in my computer. It does not recognize any type of CD's, it shows nothing and I can not read or download anything, few days a go it was working. Thanks
  • kld_hn Sep 17, 2008
    Thanks, problem solved
  • LG Master
  • 5,568 Answers
If you haven't tried reinstalling the drive, this may help:
- Open the Control Panel - Open the System folder - Click on Hardware - Click on Device Manager
Locate the DVD-CD-ROM entry and expand it. Highlight your optical drive and press 'Delete'
If it argues with you, answer 'Yes' to the question of deleting the drive(s)
Reboot your computer and watch for a message box reading that a 'New Device' was found and software for it is being installed.
If it still doesn't want to cooperate, then the drive is probably 'toast' and will need to be replaced.
Posted on Sep 15, 2008
Dell Inspiron 1420 is not able to read empty cds or DVDS. My I go to properties it shows empty space as 0. When I try to burn a Cd it says " Insert a blank CD"
Stephen buddy, we need to talk. I do NOT understand anything you are trying to describe. Okay, so you installed a FRESH Operating System and now it is NOT recognizing your DVD-rom, right? Okay, restart the computer and let Windows load up fully. Check Control Panel and check your list of Devices. Sometimes, when you re-install and O.S., you may have to update the firmware or drivers for certain devices.
Feb 05, 2014 | Dell DVD-rom DVD Drive
Dell D600 cd rom replacement instructions
There should be a screw on the bottom holding the cd rom in place. Unscrew the screw and then with one end of a paper clip put it in the small hole on the front of the cd rom and the door should open. Now go ahead and pull the cd-rom out.
Now you can go ahead and put the new cd-rom in place and put the screw in and then turn on the laptop and let it boot up into windows and windows might redetect it. Go into my computer and you should see your cd-rom in there.
Jan 23, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
Dell Lat. D600 will not read cd and does not recognize cd
this tool will fix it
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 30, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Won't recognize blank dvd
Chek wtat is written on front panel
If it DVD-RW it can record only DVD-R blank, if it + so only +R
or DVD-RAM. If it is DVD +/- RW or RAM it can record any disk.
Also chek the speed for you DVD and disk you using.
If you dvd maximum speed for recording is for example 2.7, 4, 8 you should use only DVD with max speed 2.7, 4, 8 or 1-8, 1-16 etc. So they should be labeled the same as you DVD
Good Luck
Jan 10, 2009 | Microsoft Windows XP Professional With...
Will not recognize dvd rom
Try going to add hardware in your control panel and have the dvd-drives' driver disk on hand.
What are your computers specs?
Jan 02, 2009 | Dell Dimension 2400 PC Desktop
Cd-rom
search for a decoder software on the internet and download then install
also seach for inspiration 3000 and install
Dec 28, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
My dell d600
NTLDR or NTDETECT Is Missing or Corrupt Error Message
Table of Contents secondary.gif Start the Recovery Console secondary.gif Repair the Missing NTLDR or NTDETECT File » Start the Recovery Console
  1. Insert the Windows XP CD into the CD or DVD drive.
  2. Restart the computer.
  3. While the computer is starting, repeatedly press F12 every 3 seconds to access the one-time boot menu.
  4. When the one-time boot menu appears, press the Down Arrow to highlight the CD-ROM option that appears, which is one of the following options: Onboard CD-ROM Drive or Onboard USB CD-ROM Drive.
  5. Press Enter.
  6. When the computer boots to the CD-ROM drive, press R to enter the Recovery Console.
» Repair the Missing NTLDR or NTDETECT File
  1. Boot the system to the Windows XP Recovery Console.
  2. Type map, and press <Enter>. Make note of the drive letter assigned to the optical (DVD or CD-ROM) drive.
  3. Type copy x:\i386\ntldr c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  4. Type copy x:\i386\ntdetect.com c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  5. If you are prompted to overwrite the file, type y, and press <Enter>.
  6. Type exit and press <Enter>.
  7. As the computer restarts, remove the Windows XP CD.
The files have been restored and the error message should be fixed.
You can check this website for further details.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=B93824605BF646F98FDFACA51E3A9B55&journalid=4F6F8BC06C3B5014E040AE0AB5E121D2&Query=TlRMRFIraXMrbWlzc2luZw==&SystemID=LAT_PNT_PM_D600&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Pls let me know asap if we did resolve it.
Dont forget to rate me Fixya....
Cheers.
Jun 15, 2008 | Dell Latitude D600 Notebook
CD ROM CR-589
Hi, A couple of possibilities: With a known good DVD with files inserted into your Compaq CR-589, double click in your My Computer, double click in your CD/DVD. 1. If it opens and displays the content, then there is nothing wrong with your DVD but the auto start feature of your OS was disabled, enable auto start; 2. If in My Computer or in Device Manager, the DVD doesn't show up, then it can be hardware problem, IDE/power cable problem, bios did not recognize DVD device, replace if and as needed; 3. If the DVD is in My Computer but will not display the files or contents, possibly defective DVD, replace. Hope this worksa out for you. Pls post again how things turn up. Good luck and kind regards.
Aug 05, 2007 | Compaq 32X IDE CD-Rom Drive (opal)...
LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive Logo
368 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
