Question about Whirlpool LSR5132J Top Load Washer
Washer doesn't spin or drain
I read an earlier question posted here and checked the lid switch, but it appears to be operational. The washer fills and agitates, but when it reaches the point where it should drain, it just stops. There is nothing. No sound, no humming, no nothing. It's like it just turns off at that point. I tried manually advancing the timer, but it still just sat there. Any idea what it could be? I can replace parts easily enough but I don't have any idea what to replace or where to find it.
Thanks,
  • 2 more comments
  • Paul Atchison Sep 15, 2008
    Thanks, Mohamed. I checked the timer and tried to test the spin cycle in other programs, but nothing happened. It just seems to stop when it reaches the spin cycle. I was thinking maybe it was the pump?
    Yes. Everything else seems to work fine. The washer fills, goes through the wash cycle, and when it reaches the point where the washer would drain and spin for the rinse cycle, or any other part where it would drain and spin, it just seems to turn off. No noise what so ever coming from the machine. It doesn't drain or spin.
    No I havent. But only because I really don't know where to look. Can you point me in the direction of the pump? I will go check it out. And how would I know there were anything stuck in the pump? Broken wiring is more obvious.
    Thanks!
  • Anonymous Jan 09, 2009
    how do i find the timer?
  • 126 Answers
YOU NEED TO CHECK IF THE SPIN IS WORKING ON THE OTHER PROGRAMS.IF IT IS THEN YOU NEED TO OPEN THE TIMER AND CHECK IF THE CONTACTS ARE NOT BURNT OR THERE IS NOTHING STUCK BETWEEN THEM ITS THE CHEAPEST WAY OF REPAIRING THE MACHINE LET ME NO IF YOU NEED ANY FUTHER ADVICE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
  • 1 more comment
  • MOHAMED UZAIL ESSACK
    MOHAMED UZAIL ESSACK Sep 15, 2008
    HOW IS THE WATER FLOW IS THERE ALOT OF WATER IN THE MACHINE AT THE TIME WHEN IT STOPS
    HAVE YOU CHECKED THERE IS NOTHING STUCK IN THE DRAIN PUMP.OR NO ELECTRICAL WIRING BROKEN
    MOHAMED UZAIL ESSACK Sep 16, 2008
    DEPENDING ON THE MACHINE IF ITS A TOP LOADER THE PUMP WILL BE IN THE FRONT OF THE MACHINE NEXT TO OR IN FRONT OF THE MOTOR.IF ITS A FRONT LOADER THE PUMP WILL BE IN THE FRONT LEFT OF RIGHT.IF YOUR MACHINE IS FITTED WITH A FILTER YOU NEED TO OPEN IT AND CHECK IN THERE ALSO.THE OTHER WAY TO LOCATE THE PUMP IS LOOK FOR A COMMPONENT THAT HAS TO PIPES ATTACHED TO IT ONE BEING THICKER THAN THE OTHER.IF YOU STILL HAVING A PROBLEM BEST YOU GET A TECHNICIAN TO ASSIST YOU.LET ME NO IF YOU NEED ANY FUTHER ASSISTANCE.MOHAMED
Washer wont spin or drain
Yes, you can check the LID switch as it needs to activate the program to move forward. If the water fills up and there is no wash cycle, check if the motor hums, if so check the capacitor, check the friction on the spindle/drum. If the spindle does not agitate with movement the assembly must be reset.
Jan 23, 2013 | Washing Machines
Kenmore 80 series washer will not drain or spin but will fill up how to fix it
The usual thing wrong when a washer such as the one ya have doesn't spin or drain,it's going ot be a broken lid switch. Its a pretty common thing so i have written this tip of how to check for a broken lid switch, http://www1.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
GENE
Oct 10, 2011 | Kenmore 24032\24036 Top Load Washer
Our washer wont fill with water and the controls seem to be stuck on drain and spin. no matter what we do it wont fill and wash clothes.
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. I want to thank you for reading and I hope this helps you. Best regards and thanks for reading
Apr 13, 2011 | Kenmore 22422 Top Load Washer
My lg washer will not drain fills with water and spins. when time to drain just makes funny noise. cleaned drain filter still wont drain
Thanks for choosing FixYa. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. I want to thank you for reading and I hope this helps you. Best regards and thanks for reading
Apr 06, 2011 | LG WM0642H Front Load
Top Loader LAT9406AAE s/n 23257742UQ Will not operate in any mode
if the washer will not fill I would change the water inlet valve. this could be the problem for all other issues. if the machine has no water in it, likely the timer will not advance to wash.
Oct 27, 2009 | Washing Machines
Roper RAL6245AW0 Washer Won't Drain or Spin
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Oct 13, 2008 | Washing Machines
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
May 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will fill and agitate but won't drain and spin
Tweetly, no spin, no drain, usually a sign of a broken lid switch. Also check the switch actuator on the lid. Lid switch part number 3949238. Check that out first and post back. Catriver.
Mar 22, 2007 | Kenmore 24712 Top Load Washer
No spin
Cowboy, make sure the lid switch is operational. If it is and you can get it to spin in the test mode but not in the regular cycle, sounds like a control board issue to me. Catriver..post back.
Sep 25, 2006 | Kenmore 42182 Top Load Washer
Washing Machines Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
