Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Noisy Motor My Frigidaire is brand new. It iseEXTREMELY noisy when running. The icemaker/water dispenser have not been connected yet. Any ideas what could be the problem? It is freezing just fine & no other problems.
  • Frigidaire Master
  • 5,568 Answers
The compressor is normally pretty quiet, more of a deep hum so the noise is probably coming from either the fan that circulates air inside or the one that pusshes or pulls air through the evaporator coils under the cabinet. Probably has Chinese fan motors by now -
Posted on Sep 15, 2008
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from
Oct 01, 2015 | Frigidaire Refrigerators
How to fix a noisy evaporator fan in a frost free refrigerator
The ice usually makes a fan noisy by filling the cavity it needs to move the blades in. check if this is the case, if there is no obstruction and the fan motor itself is noisy it needs to be replaced or serviced, servicing parts is trickier to find than the little motor it self.
To clear the ice just let the fridge stand for a few hours and to help the process speed up you can spray the evaporator with luke warm water.
Feb 26, 2015 | Frigidaire Refrigerators
My NEC FR510 has a continual motor running for long periods of time and it is noisy?
Is your water dispenser filter plugged? That would make the pump noisy.
Oct 18, 2014 | Refrigerators
No ice
Sounds like ice maker is bad.
Sep 13, 2017 | Frigidaire FRS26R4A Side by Side...
Noisy dishwasher
It is the wah motor. contact Frigidaire for a replacement motor that has been redesigned to eliminate that noise
Feb 26, 2010 | Frigidaire Dishwashers
Frigidaire FRS24ZRHW0 Icemaker/Water Dispenser problem
See if your water solenoid might be the problem. Your water supply line from the house will connect into a solenoid. I just recently solved a problem for someone on this site who had a solenoid that was sticking. Try tapping the solenoid gently to get it to activate or take it apart and depending on what type it is, manually move the spring loaded plunger a few times.
Hope this helps
Feb 25, 2010 | Refrigerators
Noisy 2001RM 125
Dont run a noisy motor bike or you'll ruin it. Slip it again and go see...
Apr 16, 2009 | 2008 KTM 300 EXC-E
Brand new pump that i bought it from store and i installed myself but it makes a distinctiv noise. emerson 230 v 1 hp.
is it the water going through the wet end or is the motor making the funny sound?
If the motor is sounding funny then you may have a bad motor. if the wet end is sounding really noisy then the motor may not be matching the size of the wet end as far as the HP. make sense? if your motor is bigger than the rating on the wet end it is pushing way too much water it is will be very noisy.
Jan 02, 2009 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at).
Jan 08, 2007 | Frigidaire FRS26R4C Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
145 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
