Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System
Problem for Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with...
Kenmore 10654382300 side by side
By vdimondi on Sep 15, 2008
Refer side wont maintain temp... upper part of door not sealing....door seal shot?
Condensation in the freezer also....are they related?
Thanks
Vince
Solution #1
posted on Sep 15, 2008
Not Rated)
Scott Ellin
Rank: Wiz
Rating: 83%, 326 votes
Hi Vince,
Thanks for the posting in FIXYA.
Please repair the Freezer door as it is not sealing, due to which cooling is affected. If it is under warranty then contact to the manufacturer as soon as possible.
Regards
ELLIN
Solution #2
Not Rated)
ghappliances
Rank: Guru
Rating: 88%, 64 votes
HELLO VINCE.WITH REGARDS TO THE TEMP IN THE FRIDGE SECTION NOT STABLE THAT IS A RESULT OF THE DOOR SEAL ITS BEST YOU GET THAT REPAIRED ASAP AS THAT WILL RESULT IN THE FRIDGE RUNNING FOR A LONGER PERIOD.THE CONDENSATION IN THE FREEZER SIDE DEPENDS ON WERE IT EXACTLY IS IT DOESNT SOUND LIKE ITS RELATED IT MIGHT ALSO BE THAT THE FREEZER RUBBER ALSO NEEDS REPLACING.LET ME NO IF YOU NEED MORE ADVICE.GOODLUCK.MOHAMED
Solution #3
Not Rated)
Ajkill
Rank: Wiz
Rating: 84%, 1104 votes
Yes this is the problem with door seal as it maintains the inner temp and outer temp >Seal is its broken or shot then out side air will enter and condensation forms ,please fix the door seal .....
Good luck...
Popular Solutions for Kenmore 25.1 cu. ft.
Questions and Unsolved Problems for Kenmore 25.1 cu. ft.
Do you recommend Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System?
Answer
Answer
kenmore refridgerator 106.56703500, flapper inside ice dispenser has come out of its snap in slotts.... (More)
Answer
kenmore model 106.56703500 makes ice but the dispenser on the door does not work, neither dispenses... (More)
Answer
when the ice maker start to rotate there is a very loud repeated pecking noise
Answer
I have a kenmore elite side-by-side refrigerator freezer. The rotating faucet (on the door) won't... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
