Question about Brother ULT2001
Bobbin thread shows through fabric ALOT
ULT2001
  • 4 Answers
When this happens you need to adjust the tension down. If it's set at a default of 4 move it down to 3.5 or even down to 3 sew a bit check. Certain threads do this more (Sulky) on the brother than others (Maderia), but the black lettering in the embroidery feature always seems to need adjusted. The tension adjustment is the same for sewing or embroidery mode.
Posted on Nov 23, 2008
Model number 4562. The bobbin thread bunches up. How do i fix?
Check your stitch sample. Is it the bobbin thread that is making a thread mess, or is it the top thread throwing thread globs under the fabric? Usually, if there is a thread problem under the fabric, it is a top thread issue.
Try this:
Remove the top thread completely from the machine.
Install a brand new needle
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Retest your machine and tweak the tension, as needed. If top thread is showing under the fabric, tighten the top tension. If the bobbin thread is showing on the top of the fabric, loosen the top tension. Tension is correct when the two threads meet in the middle of the fabric.
Feb 26, 2018 | Sewing Machines
The tension on the top is out of sync. Don't know what to adjust. Help
Since we don't have a clear picture of what is happening, we can't offer much in the way of advice. Here is something to try:
Remove the top thread from the machine.
Be sure to install a brand new needle.
ALWAYS RAISE the presser foot and rethread the top thread from the beginning. Verify the thread path is correct.
Remove the bobbin and rethread it into the bobbin case and install it in the machine. Make sure the bobbin is turning the correct direction in the bobbin case.
Set the top tension to the midway point (the factory standard tension).
Retest the machine.
HINT: Thread issues appearing under the fabric are usually a top thread problem. Thread issues appearing on top of the fabric are usually bobbin related.
If bobbin thread is showing on top of the fabric, loosen the top tension.
If problems continue, the bobbin tension may also need to be adjusted. HOWEVER, that is a last resort and a very tricky change to make. Be sure to mark where the tension screw is set BEFORE making any changes to the bobbin tension screw (so you can reverse your changes if it doesn't work).
You can also try changing the type & size of needle and the brand/weight of thread. AVOID old or bargain bin threads. Your needle choice, thread, and fabric should be compatible. Using the wrong needle can cause huge problems with stitching success.
Understanding Thread Tension Threads
Feb 14, 2018 | Sewing Machines
Moved my tension button and not sure what to set it on, sewing polycotton curtains
uually your tension should be set between 4and 5 this is a good tension for most fabric
Dec 27, 2017 | Sewing Machines
Upside down stitching
Am having a difficult time picturing this. Sounds like the upper thread is creating loops under the fabric and the bobbin thread is showing on the top of the fabric.
Make sure to use a brand new needle.
Remove the thread from the machine
ALWAYS raise the presser foot and rethread the upper thread.
Make sure the thread path is correct.
Check that the bobbin is turning the correct direction in the bobbin case and the bobbin thread is threaded through the bobbin tension correctly.
Set the upper tension to the midway point (factory standard), however, this setting may need to be tweaked for your particular machine.
Bring the bobbin to the top of the project Before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Retest--begin sewing slowly.
If the upper thread is still showing on the other side of the fabric, the tension is too loose. If it is pulling the bobbin thread up to the top of the fabric, the upper tension is too tight
OR the bobbin thread tension is too loose. (CAUTION: make only small adjustments to bobbin tension--1/8 of a turn at a time!!! It also helps to mark the screw groove location with magic marker on the bobbin case BEFORE making any changes so you can back it out and return to the original setting.)
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 05, 2016 | Sewing Machines
Top thread covers bobbin thread makes. Stitches very thick
Remove all the thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot during the threading process and rethread the machine from the beginning. (Check that the upper and bobbin threads are threaded correctly in your machine.)
Set the tension dial to the midway point. This is a factory standard setting but each machine may vary.
Test your machine. The ideal tension is when the upper and bobbin threads meet in the middle of the fabric. If the upper thread is showing on the bobbin side of the fabric, the upper tension is too loose. However, if the bobbin thread is showing on the top of the fabric, the upper tension is too tight.
Tension is not static--whenever you change projects, ie fabric, thread, needle, you may need to test the tension on some scrap project fabric first. Get the tension adjusted before stitching the project.
Make sure you clean and lubricate your machine regularly to keep it operating--consult your owner's manual and use only good quality sewing machine oil (NO 3-in-1, cooking oil, WD-40, or old brown stinky sewing machine oil).
If you are still having issues, take it for service.
May 27, 2016 | Sewing Machines
Why is the bobbin thread bunching up?
if your saying that your bobbin thread is balling up under the platen plate , this is a sure sign that your top thread tension is not correct and there isn't enough tension to pull the bobbin thread up from below
Mar 24, 2016 | Sewing Machines
What makes the stitches loose? How do I make them tight?
You should have a tension knob (1 to 10) on the machine, the lower the number the tighter the tension.
Jan 09, 2016 | Sewing Machines
Breaking cotton on top and bobbin
Try loosening the tension for that bobbin
Dec 15, 2015 | Sewing Machines
Bobbin thread shows on embroidery pattern
The bobbin thread is being pulled too hard by the top thread. The idea is to get an even pull similar to a tug of war. When it is even the thread will form a knot in the middle of the fabric.
To fix this so the top thread isn't pulling too hard lower the tension of the top thread. This should fix it.
May 08, 2015 | Janome Memory Craft 10000
Bobbin shows on top
I took it to be serviced.
Feb 28, 2009 | Brother ULT2001
Sewing Machines Logo
97 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
