Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore Washer/Dryer Combo Unit Cord Issue
I have a five year old Kenmore Washer/Dryer Combo Unit. I recently moved to an apartment where the outlet is brand new-it has four prongs. My washer/dryer has a three prong cord. I purchased a new dryer cord with four prongs to replace the the three prong cord with. My question is how do I prevent the dryer from drawing too much power from the outlet terminal given that it will be going from three prongs to four? I was told there is a certain way I have connect the new cord to prevent this and risk of fire.
Thank you.
  • 2,307 Answers
Click here for more info on the electrical connections from a 3 to prong.
I would suggest to check with the superintendent of the building first before hooking the appliance. That way you will know if the wiring will be able to handle the amount of power require to operate the appliance.
Posted on Sep 15, 2008
    Genius:
  • 2,035 Answers
There is always at least one [usually more] that say to connect both green wires together.The green wire that is already on the dryer[not the one from the cord] is connected to the center neutral connection but it is connected on the back side of the block.This is why the picture show you to connect it to the same post as the neutral from the cord.Basically you just made it loop from one point on the neutral to another point on the same neutral and this disables it without removing it[saves it for future use if the dryer is move to a 3 prong outlet] If you were to connect the two green wires you would be bonding the ground and the neutral together.This would defeat the whole purpose of the fourth wire.You are trying to separate the ground and neutral because the neutral is returning power back to the panel for the 120 volt controls and the ground is a safety that should not have power on it unless there is a short in the system[which would trip the breaker]
and use this link:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Good luck...
Good luck....
    Master:
  • 726 Answers
The extra prong is just anothere earth over here we hacve three prongs and 2 prongs its just a better earth thats all and it wontstart a fire ii always change mine i did it to my toaster,microwave,iron,and pc all over 1 yr ago nothing ever happened
I have a Kenmore Elite electric dryer model # 11063932102 that will not start. It was in storage for five months and it had some superficial mice issues on the body, which cleaned up nicely, but now it...
Did you replace just the plug end of the existing cord or the entire cord/plug cable at the dryer connection? You cannot just replace the plug end since the 4th connection is not made it won't work. The easiest solutiuon is to use a 3 to 4 prong adapter. See this video that explains it.
http://www.youtube.com/watch?v=ZBJhkyHSCmo
Nov 02, 2014 | Dryers
We just recently moved and the original house had a 4 prong dryer connection which my Matag neptune has. The new house has a 3 prong outlet. I have purchased a 3 prong cord. How to do I hook up the...
DON'T DO IT!!! Get an electrician to install a 4 prong outlet for you. Your exposure is DEATH, be safe and get the correct outlet.
When some types of failures happen, you can charge the CASING of the washer. then you can become the connection to ground.
Get the correct outlet, return the three wire plug.
Jun 24, 2011 | Dryers
We moved our Kenmore stacked washer/dryer from downstairs to upstairs - now it will not work. any ideas?
If the dryer didn't get banged around or damaged when you moved it, it sounds like it might be a power issue. Is the outlet where the dryer plugged into controlled by a switch? If so, make sure the switch is on. Is it on an electrical circuit with any other large devices (air conditioning unit, refrigerator, etc.)? If so, the dryer probably isn't getting enough power. Try plugging it in somewhere else, on a different circuit (using an extension cord to test it, if you don't want to move it until you're sure) to see if that makes a difference.
Jan 15, 2011 | Kenmore 98702 Stacked Washer/Dryer
After spin cycle is complete, clothes in washer are still too wet
Check for obstructions in the pump and discharge hose. Check the motor coupler. Here is a video that should help.
http://appliancehelponline.com/topdirectdrivevideo.html
Jun 04, 2010 | Kenmore 22422 Top Load Washer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Landlord wants to know what type of plug is on my dryer. Dryer is in storage. Dryer is about 8 years old. Is there a common type?
It's either a three prong or four prong plug. He'll need to change the outlet to match the dryer or change the dryer plug to match the outlet.
Oct 23, 2009 | Dryers
Longer cord/age of washer & dryer
Is your dryer electric with the big plug.
If so, what kind of changes are you making?
The dryer needs to be by the vent outlet so you can't move it far unless you are going to cut a new venting outlet.
If it is electric (not gas) then do not try to extend the cord. Have a licensed electrician move the electrical jack.
The cord has a large amount of current running through it and the longer the cord, the more resistance the current has to flow through. More resistance means more heating of the cord and less voltage for your dryer. This can result in the cord overheating to the point of melting and starting a fire itself or getting hot enough to ignite the very fine and very dry lint particles that are present in any laundry room.
This is a situation where you spend the money and have it done professionally because of the danger of fire, death, etc.
Good Luck!
Oct 09, 2009 | Dryers
Dryer won't start
check to ensure you have voltage at the outlet
the four wire pattern goes like this
black far right
red far right
white in the middle
geen to the chasis
Oct 01, 2009 | Maytag Dryers
Kenmore 98702 Stacked Washer/Dryer Logo
172 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
