Question about Intel D915GAV Motherboard
Powers for 2 seconds
When I hit the power button it comes on for 2 seconds then powers off. I am using 1066 front bus processor would that be the problem?
  • Anonymous Oct 09, 2008
    what can I do
  • Daniel Jenkins
    Daniel Jenkins May 11, 2010
    The board could be in self protect mode. Try unplugging power, then press and hold power button for 10 secs. Plug power back in and see if it powers up. If it doesn't or the problem has not changed, I would say you may have a bad board.
    Scholar:
  • 172 Answers
Sounds like a heat problem, i.e. cpu overheat, check cooling fan.
Posted on Sep 15, 2008
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Like to upgrade I have DG 965 RY LGA 775 Socket
Hi, your motherboard supports several different kinds of processors. You have a choice of two for the fastest performance. You could go with an Intel Core 2 Duo Processor #E6700 that runs at 2.66 Ghz with a front side bus of 1066 Mhz and 4 Mb L2 cache, or you could go with an Intel Single Core Processor #670 that runs at 3.80 Ghz with an 800 Mhz front side bus and 2Mb L2 cache. The Core 2 would outperform the Single Core, but it is more expensive. Hope this helps! Hal
Jun 03, 2009 | Intel DG965RY Motherboard
Max processor for upgrade?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Theoretically, it's support up to Core2Duo with 1066 Front Side Bus, but some source in Intel Website said that it's chipset (Intel946GZ) can afford until Core2Duo E7500 (1066FSB), to be honest, my L310 using E6300 which is have 1066mhz FSB. So I think it should be ok if run with higher Core2Duo, but I suggest to do bios firmware update before change your processor.
Apr 07, 2009 | Acer Aspire L310 (ASL310UD631A) PC...
Upgrade cpu
It is a bit of a crapshoot trying to upgrade a processor from a major manufacturer. Their motherboards are designed specifically for the manufacturer and documentation on exactly what will work NOW compared to when the unit was new is rather hard to come by. They don't support people upgrading very well compared to the aftermarket manufacturers.
You should go to dell.com and put in your service tag to check your exact configuration yourself before spending any money.
According to Dell, the Dimension 5150 has a motherboard that uses the Intel 945G Express chipset. You can see INTEL'S documentation on that chipset's capabilities here. According to that documentation you can use a socket LGA775 with up to a 1066 MHz system bus speed.
Looking at Newegg, the fastest LGA775 processor with 1066 MHz are a 2.93GHz Duo core or a 2.4 GHz quad core. Again, no guarantees either will work with your system, and you definately want to make sure your power supply and case cooling are up to the task.
Mar 21, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
AKAI PDP4273M1 - Unit powers up then shuts down.
I just repaired one for the same trouble. The input to the main processor from the standy switch had shorted to groung. This was probably caused by static inserted when pushing the power button. The processor is not a replaceable part. The part number for the main board is E3761-058010-2. It costs between $140 and $150. I found it on-line at Shopjimmy.com.
Good Luck!
Jan 29, 2009 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Whirlpool Duet washer won't power on
push in the end of cycle button hold for a few seconds
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dell Dimension E510 Powers Up, Then Crashes
It's the processor or power supply. I cant be sure of which without checking it.
Check the fan over the processor heat sink to make sure its working cause it could mean that the processor is overheating If the fan turns and then it cuts off this could meant that the processor is dead. or the bios is corrupted. Try flashing the bios, there is a battery on the main boad, remove it. unplug the system first... when the battery is out press and hold the power button for 10 seconds then release. put the battery back in and try to turn it on..
If that fails then try a new power supply or one from another system to to check if the power supply is fine. YOu can aslo bridge the green and any black wire from the power supply's mainboard connector to see if the power supply runs. If all this fails then you may need to replace your processor,, I';d also recommend changing the power supply as well.
Nov 14, 2008 | Dell Computers & Internet
Power down
Windows does not shut down. Additional information and causes that may cause Windows 95 or Windows 98 to freeze, hang or lockup when attempting to shut down the computer.
How to restart or shutdown the computer in DOS. If you are currently in DOS and need to turn off the computer press the power button. Note: some newer computers may not allow the computer to be shut down ...
Installing a pc computer power supply Write down important information from the top or bottom of the power supply such as the Model Number, Serial Number and specifications (such as voltage...).
Basic floppy disk drive troubleshooting Power down, unplug, and open computer, being aware of ESD and its potential dangers. Verify that the floppy connection is connected to the motherboard FDD .
Good Luck, Read and follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | Intel Motherboard
Intel D915GAV Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
