Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher&Paykel Intuitive Eco 'Help, I need water'
My washer stopped in the middle of the wash cycle, and is no longer getting water through. I checked the hoses and faucets, and they are fine. When I tried again, it spurted water, and then the tub spun but no water came out. I've tried a couple times since, and it's the same story.
    Problem Solver:
  • 6 Answers
If the water is coming into the machine in spurts, you may have a problem with the out of balance switch but it's very difficult to determine by your description & also without knowing the model number. The manufacturers call center is open 24/7 if you want to call them - you can get a number for a repair guy too from them.
Posted on Sep 17, 2008
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
Sep 20, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive Eco switching itself off during cycle.
Could be a bad drain pump or controller or rotor position sensor. You will need a Tech to take a look. Unfortunately with these machines there can be many reasons for a failure. Call F/P to get a certified technician out there.
Jun 14, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Out of balance during wash
Ok you need to check your machine is level- if not adjust feet. You aslo need to check the Bias spring is still attached if not get a new one or re-attach it. The Bias spring is a little spring that connects from the top of the front left suspention rod to the top of the plastic bowl cover (this spring is meant to help stop it going out of balance so easy. Cheers
Mar 24, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Jan 23, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Gwl 10 washer
Check that the pump isnt blocked.
Mar 01, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
