Question about Kenwood Sirius KDC-MP825 CD Player
Kenwood KDC-MP825 rear speakers wont work with amp connected.
I have had this head unit for a while but it has moved between cars. I recently decided to add some components speakers into the mix. I bought an amp and speakers when i got it all hooked up the only thing working were the components running from the amp. The rear speakers that are connected to the head unit are no longer working. Is there somthing that i need to set up to get this to work properly
robotek
  • 1512 Answers
SOURCE: Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Posted on Feb 08, 2008
  • 29 Answers
SOURCE: kenwood kdc-mp 825
it's a Canadian Kenwood.
http://inform3.kenwoodusa.com/manuals/KDC-MPV8025.pdf
I had the 925 purchased from Ebay, but I sold the car with it.
it's probably the ribbon wire broken between the face and the unit. I know that on Ebay some they use to offer a repair for these type of units.
Posted on Sep 07, 2008
  • 3 Answers
SOURCE: Kenwood KDC-MP825 car stereo problem
My wife experienced the same problem this month, December 2008, after owning the KDC-MP825 for 3.5 years (what's up with that?). It would power on briefly, the panel would move, then after 2 seconds it would shut down. After 15 seconds, it would power again, panel motors whir, then shut down. It would keep doing that while the key is in ignition.
This appeared to have solved the problem:
Hold down BUTTON [5], press the RESET button (you'll need a ballpen to press between the AUTO and SCRL button).
This was the procedure for getting the receiver out of demonstration mode. Maybe the cold weather here in New Jersey placed the unit into demo mode?
Posted on Dec 08, 2008
tech48
  • 624 Answers
SOURCE: unlock code
This is the only way to clear the code. You must have the remote to do this, it will not work without the remote. I work at an authorized Kenwood service center and tell you for certain that this is the only way it can be done. If you do not have a remote, you will either need to buy one or borrow one from somebody else who has a Kenwood radio. Most all Kenwood car stereo remotes will work, it does not need to be from the same model number but it must be a Kenwood car stereo remote. If you can not find a remote for this then you will need to take the radio to an authorized Kenwood service center and they will usually do it for a small fee.
The first step is the only part of this procedure that you do not use the remote.
1. During code request mode, press the Track UP key for at
least 3 seconds while holding down the AUTO key. (– – – –
will disappear)
2. Enter, “KCAR” with the remote controller as described below.
• Press the remote controller 5 key twice, and press the Track
Up key. (Enters a “K” )
• Press the remote controller 2 key three times, and press
the Track Up key. (Enters a “C” )
• Press the remote controller 2 key once, and press the Track
Up key. (Enters an “A” )
• Press the remote controller 7 key twice, and press the Track
Up key. (Enters an “R” )
3. Security function is canceled and unit sets to All-Off mode.
4. Code request mode appears if a mistake was made in entering
the numbers.
Posted on Dec 12, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenwood kdc-mp532u Auxiliary?
http://inform3.kenwoodusa.com/manuals/KDCX590.pdf - Manual
iPod Adapter Compatible: Using the KCA-iP500 iPod Control Interface, you can connect your Apple iPod digital music player to this receiver. The interface (item # 113IP500) plugs into the receiver's 13-pin CD changer input and controls the iPod through the receiver's controls, as well as displays the iPod's text information right on the receiver's display.
Posted on Dec 30, 2008
Need a stereo wiring diagram
Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
Feb 01, 2013 | Kenwood Sirius KDC-3025 CD Player
When i power it on it shuts off i got a kenwood kdc-mp825
Disconnect all of your speaker leads at the head unit, make sure none are touching, then power it back on. If it still cuts out, check your ground, if it doesn't, re-connect speakers one by one and test power again. It will either cut out when you get to a speaker or wire that's shorted, or work just fine. it's protecting itself from damage by cutting off when speakers are either bad or have shorted wiring. Most common shorted wiring happens on door speakers at the hinge. If it continues to cut off without speakers connected and you have a good ground, the unit needs service. If it still plays and you find the speaker or wire that's causing the problem, disconnect the wire at the speaker and test again, if it works, replace the speaker, if it doesn't, replace the wire. Hope this helps
Jul 07, 2011 | Kenwood Sirius KDC-MP825 CD Player
I just purchased a new kenwood KDC-138 head unit as well as two car speakers. The speakers were able to be installed onto my 2000 mercury cougar but the head unit gave me some troubles. The wires on my new...
The following will help you out. The first is for the vehicle and the second for the stereo. Good Luck.
Constant 12V+ Orange/Black Switched 12V+ Yellow/Green Ground Black/Green Illumination n/a Dimmer White/Green Front Speakers 6" Doors Left Front (+) White/Black Left Front (-) Gray/Black Right Front (+) White/Red Right Front (-) Gray/Red Rear Speakers 6" x 8" Side Panels Left Rear (+) White/Purple Left Rear (-) Gray/White Right Rear (+) White Right Rear (-) Gray
May 16, 2011 | Kenwood KDC-138 FM / AM Receiver
Kenwood eXcelon radio problem I have 2 subs in my civic that work perfectly fine but i recently tried to add another amp to run my front door speakers seperately. I spliced the remote wire between the two...
Cut the remote wire from the radio.
install a relay in line
the relay will have 4 or 5 terminals
connect terminal 87 to battery power and fuse it at 3amps
connect terminal 86 to the remote output from the head unit
connect terminal 85 to ground
connect terminal 30 to your amp turn on wires
this allows the turn on load to run thru the relay and not directly off the radio remote output
Nov 25, 2017 | Kenwood Kdc-x494 Car CD/ MP3 Player
Kenwood kdc-mp 825
Sep 06, 2008 | Kenwood KDC-MP828 CD Player
I just bought a KDC MP-235 to put in a 95 camaro with bose amplified speakers. I ordered a amplifier intergration component to reduce the output of the 50 watt per channel head unit as to have better...
Yes, the Kenwood KDC MP-235 has two (2) line level outputs (RCA types red & white). However, these outputs internally passed through an electronic crossover/filter making them appropriate for subwoofer amps only.
If your unit is an MP-235CR, then the same outputs would be for the rear amp (not subs) and are full range (unfiltered).
If indeed your unit is an MP-235 and if I may make a suggestion, still connect the Kenwood to four (4) speakers. It would not be technically correct to leave the internal amps operating with no load (speakers) connected. Additionally, you would be getting 200 watts (4 X 50) more to your system (since it is already there).
If your Bose amp & speaker are subs, then no issue, however if the Bose is for a full range of speakers, then only the woofer part would be working efficiently.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | Kenwood Car Audio & Video
Kenwood CD player KDC-MP825
Some units have a reset button, have you tried to reset the unit?
Feb 10, 2008 | Kenwood Sirius KDC-MP825 CD Player
Aug 20, 2007 | Kenwood KDC-MPV8025 CD Player
Audio Output problems
Currently you have the blue wire from your Kenwood head unit connected to the blue wire in the Chrysler wire harness adapter. You need to disconnect this wire, and reconnect it to the blue/white wire coming from your Kenwood head unit instead. You probably already have the remote wire from your subwoofer amp connected there; both wires need to be attached to the blue/white Kenwood remote output. Your LHS is equipped with a factory amp. The blue wire in the Chrysler harness activates the amplifier, but it's connected to your Kenwood's power antenna activation output; therefore it's only being turned on when the tuner is selected.
May 30, 2007 | Kenwood KDC-MP828 CD Player
Kenwood kdc-mp528 amp/speaker problem???
This is a common mistake. This problem indicates that you are using the solid blue wire from the head unit to the remote turn-on on the amp. This is a power antenna wire that only receives power when on FM radio. You need to replace this with the Blue & White wire from the head unit (power control wire) to your remote turn-on on your amp. This should solve your issue.
May 12, 2007 | Kenwood KDC-MP528 CD Player
Kenwood Sirius KDC-MP825 CD Player Logo
47 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
