Question about Canon Office Equipment & Supplies
Canon Pixma IP4200: Error message "two yellow cartridges are installed" even though this is not the case. All cartridges are new and manufacturer's originals. All tanks are full. Please advise how I temporarily cancel cartridge monitoring until the ink is used up and I can replace this cartridge. John Hargreaves
4 Suggested Answers
SOURCE: Canon PIXMA iP4200 won't print
I solved the problem (I hope more than temporarily) by going out and buying a new yellow ink cartridge. The new one seems to be working, but the cartridge that generated the error message was brand new, too - hardly a satisfactory outcome. I worked out that buying a new cartridge would be slightly cheaper than signing up for one of the Canon support plans. As you can guess, this experience does not augur well for me buying more Canon products in future.
Roslyn
Posted on Aug 20, 2008
Douw
  • 91 Answers
SOURCE: canon Pixma IP4200 started printing regular
Hello first of all are you technical
I have taken the printer head out
boil some water and pour in a cup
take off the 2 screws at the bottom
gentley open the head from the casing**** note if you not gentley it wil brake and U can through the hole head away
then let the white block lie in in the water until the water is cold the trough that out and repeat this step.Boil water again....Wait for 4 to 5 minutes to pass..... then use high copressed air and blow from the underneth so that the presure will force the **** out on the white block side also force some hot water from the litle sifes at the top down and make sure that holes are open
replace the ruber perfectley and the head pease an make sure every thing is propeley dry.Replase the scews .and put it back in the printer.Remember it is also a very filthey and inkey job.Good luck
Posted on Feb 15, 2010
SOURCE: canon pixma ip4200 green &
You might need to reset your printer so it can work again. please follow the steps below. It is important to familiarize yourself to the steps before doing it.
Here it is.
With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button.
Do not release the buttons. The LED light should be green to indicate that a function is selectable
While holding the Power button, release the Resume/Cancel button, do not release the Power button
While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
Press the Power button. The LED lights in green, and the reset is performed.
When the operation completes, the printer returns to the menu selection mode automatically
Press the power button to exit service mode.
Hope this helps.
Posted on Apr 24, 2011
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Cartridges don't work
Sounds like you got a defective cartridge, it happens once in a while. On some Canons, you hold the resume button for 5 seconds and it will ignore the error, not sure on your model printer.
Jul 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon iP4200 thinks it has two yellow ink catridges installed
I have had this happen a couple of times to me with a few cartridges so if you can be sure it's just the black that has changed then I'd contact your retailer and request a replacement under warranty.
The only other way to solve this is by process of elimination using some other cartridges. If you know of someone else with a similar printer model that uses the same cartridges then perhaps ask nicely :)
Feb 13, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Roslyn
Aug 20, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Ink light flashing
whip the cartridge circuits with the tissue paper, if the problem occurs the same thing than this is the service station error mean s the software has to be installed again
Mar 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Poor print colour
use new cartridge for your printer
Mar 19, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printer
Sounds like you head has gone. JO
Feb 07, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
More than one yellow cartridge installed
No
Buy a new cartridge. The little chip in the cartridge is bad. Contact Canon and see if they will replace the new cartridge for you. Canon is a good company and may send a new cartridge right to your door.
Dec 29, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
128 people viewed this question
old marine
old marine
