Question about Remington Polesaw Wizard
Need gear train repair for Remington pole saw? Motor runs but saw stops in cut.
  • fishhookk119 May 11, 2010
    need part #10771301
  • 211 Answers
SOURCE: Remington Pole Saw Model 106890-02
hi
if you were used the correct oil-gas mixture,because of overheating the engine probably you need to change the piston ring.Check the piston first(take off the mufller and take a look,if there are screaches at the piston is not good).
regards savumihai71
Posted on Dec 02, 2008
SOURCE: what type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Posted on May 25, 2009
dontbother10
  • 2220 Answers
SOURCE: chain fell off chain saw remington 10
Look from the side of the saw the motor/engine to left and the bar nose to the right. The thinnest part of the chain (sharpened edge) on the top of the bar is to the right.
Posted on Sep 27, 2009
  • 4088 Answers
SOURCE: Am I wise to purchase a Remington Pole Saw or
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
Posted on May 11, 2010
LOOK UP ( PARTS FOR.COM ) FOR THE TRIGGER SWITCH
Posted on Oct 08, 2010
Need brushes for a 111409-01 branch wizard
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
May 03, 2014 | Remington Electric Chain Saw
Trouble starting
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Apr 19, 2014 | Remington Electric Chain Saw
Extremely weak motor model 108526-01 remington
Feb 12, 2014 | Remington Garden
Are brushes available for remington 106890-02
Nov 06, 2013 | Remington Electric Chain Saw
Stopped running
If the saw got bound in the cut it may have popped the breaker on the saw. Find and reset it
Jun 14, 2013 | Remington 111409 - 01 6" Branch Wizard...
Where can I get brushes and at what cost?
Parts for Remington saws are few and far between. Brushes are a common failure point and those available have about been bought up. You best chance is to check with a well-stocked hardware store or an electric tool repair shop for a similar brush from a different tool. You may have to modify something similar to fit. Good luck!
Dec 11, 2010 | Remington 111409 - 01 6" Branch Wizard...
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
May 11, 2010 | Remington Electric Pole Saw
Remington pole saw
Problem is most likely in the trigger switch on pole. Bypass switch and test bu plugging lamp into power cord coming from pole
Jan 07, 2010 | Remington Electric Pole Saw
Have a Remington electric pole saw blade stops when you apply pressure to cut
The drive sproket is stripped out. The small plastic gears inside the sproket are worn out causing your problem.You can order part 107713-01 from 1-800-654-8534
Oct 05, 2009 | Remington Electric Pole Saw
Pole saw stopped. May be in motor as sparks were seen when it stopped. Should I try to find someone to repair or re-purchase ???
It is probably the brushes that need to be replaced. They should be easily accessible and inexpensive to replace.
Here is a link I think could be useful to you: http://www.remingtonchainsaw.com/polesaw.html
May 24, 2009 | Remington Polesaw Wizard
Remington Polesaw Wizard Logo
54 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
