Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
GE Profile Smartdispense water filled bladder and stagnated
I've had this dishwasher for a little over one year and have never used the Smartdispenser (always used tablets). Dishwasher began emitting a horrible smell, and upon investigation I found the Smartdispense bladder had filled up with water and the water had become stagnate.
I drained the bladder and filled the Smartdispense with liquid (gel) detergent; this has removed the odor.
Has anyone else experienced anything like this, or does anyone have any idea as to how the bladder was able to fill with water (I would imagine the water must have went through the dispenser membrane and pump, which is a serious design flaw on GEs part).
SOURCE: GE Profile SmartDispense clog
I have the same problem and found the below on the GE website. It says to purge the detergent from the Smart Dispense. I am in the process of doing it now...we'll see if it works:
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Posted on Sep 16, 2008
SOURCE: smart dispense detergent dispenser
There are two different types of dishwasher detergent types, bleach based and enzyme based.  The owner's manual states that if the two are ever mixed that the mixture will congeal, clogging the dispenser.
I don't know exactly how to safely remove the detergent that is in there, perhaps a wet/dry vaccuum.  There is likely a service mode for the dishwasher if it has electronic buttons, in the service mode you could activate the pump that dispenses the detergent.  Use caution, the thicker the clog, the harder the pump has to work and it may fail.  Hope this helps.
Posted on Apr 15, 2009
  • 81 Answers
SOURCE: detergent dispenser doesn't empty completely
The detergent reservoir should pop open allowing the wash water to "wash" the detergent clean. It sounds like your DW is not "spraying" with full force. From your description, it sounds like your water pump is malfunctioning OR your drain is clogged with food and the water flow is restricted, because the wash water is the original rinse water from the first cycle and it recirculates. Check and make certain your drain is not clogged before you call the repairman or replace the machine.
Posted on Apr 24, 2009
erpaalai
  • 999 Answers
SOURCE: Detergent left in dispenser cup
You either do not have enough water getting itno the machine or it is not hot enough. 5 years old so I would suspect a plugged screen on the fill valve.
Eric
Posted on Dec 11, 2009
marka19
  • 1430 Answers
SOURCE: Water remains under the 4
First make sure your homes drain pipe is not plugged up. If not remove the drain hose where it connects to the drain pump. you will see a flapper valve(thin rubber piece) #328 in the diagram,this is probally allowing water to flow back into the machine. A common problem with this model the flapper gets torn or worn out. They are inexpensive and easy to replace. Enter your model # at www.appliancehelponline.com and diagrams will come up for your model.
Posted on Nov 05, 2010
Replace rubber seal
You don't give the complete model number. If you are referring to the tub gasket that surrounds the opening (on three sides) when the door is lowered, it is held by friction in its groove. If it doesn't stay in place when fully pressed in, replace it with (most likely) WD08X10032.
Nov 08, 2013 | General Electric PDWT380VSS GE Profile...
Purging ge profile smart dispense dishwasher
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Jul 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile dishwasher with ''SmartDispense'' technology is clogged
Check the reservoir hose , and unclog it if necessary. You may need to disassemble the reservoir/dispenser to solve the problem.
Use to the diagrams below:
Apr 06, 2009 | Dishwashers
Put wrong soap in the SmatDispense container...
If you run it as is you will have a kitchen full of soapy water.
Take a pot or pan. Fill it with COLD water. Our it into the DW. Fillit to the regular water level, about 1 inch below the bottom rim.
Set the DW to a pump out setting and drain it.
You will have to repeat this several times to clear the soap out.
COLD water pump out. Cold water pump out etc.
Do not use HOT water. You will get instant suds and lots of them.
Mar 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ge profile, will not fill with water.
if it is a ld-12 it is the control board
Feb 02, 2009 | LG 24 in. LD-12BW5 Free-standing...
GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
C5 error on GE Profile dishwasher
C5 - Low Water Fill - This error usually indicates bad water inlet valve. Check for low water pressure to unit.
Dec 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
DIshwasher Cycle TIme INcreases by 20 minutes over two years
Try cutting the breaker off for 5 min, This will reset the control. The issue is in order for a dishwasher to clean the dishes properly the water in the dishwasher needs to be at least 120 deg f. If its not the dishwasher keeps adding more time with the heater on to try to achieve this temp. The dishwasher only uses about 1 gallon of water per fill so if the water heater is a ways away or the temp is not hot enough, the water temp in the dishwasher will not reach 120.
Jun 11, 2008 | GE Profile PDW8400J Built-in Dishwasher
Apr 20, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
112 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
