Question about Canon ImageClass D880 Copier
Printer port i used the install disk and it will not print - it says printer port is busy
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Usually port 1 but you can select which one if that's busy.
Posted on Sep 15, 2008
My Sharp copier AR 5316 does not work with Vista business service pack-1. It does not work when print option given for current page and printer sleeps and does not take the printing order. One has to...
have you installed the PROPER Vista driver? Or just used the install disk that may have come with your machine years ago, and may not be designed for "Vista". Go to sharp and download the proper driver, or at least see if it is supported.
Feb 01, 2010 | Sharp AR-5316 Advanced Digital Imager...
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
Dell 2330dn - my printer won't print my work. It keep reading Parallel busy. What does this mean?
How is this printer connected to your computer? Is it connected by a parallel/centronics cable, or USB, or perhaps not connected physically at all, but via network (it's a network-capable printer)?
Also, you don't specify the operating system.
I would guess, that it was installed on the LPT (parallel) port, instead of a network port, and because in reality nothing is connected to the parallel port it is producing an error (explaining why it's called busy would be long and boring).
Anyway, please either check the setting of the port to which this printer is printing (find that in Printer Properties), or be more specific as to what your current situation is.
Dec 01, 2009 | Office Equipment & Supplies
Dell Photo AIO Printer 924 - Printer Busy
Might need a new printer. Lexmark printers can be troublesome.
Jul 14, 2009 | Dell 924 All-in-One InkJet Printer
Light is blinking, doesnt print, it prints before but now it doesnt. appears online and ready on the computer.
If the port had been changed to LPT1 the printer will not work.
LPT1 is the large parallel port, while you are using USB on this printer.
the red light came on probably because of a jam , or because of one of the documents in the printer cue.
The easiest thing to do is
Unplug printer usb.
Go to control panel>installed printer.
Delete all the instances of this printer from there and chose to delete drivers if asked.
Reistall the printer using the printer disk, plug in printer data cable only when asked by setup wizard.
If you have a different USB cable, also use it, just in case.
If that does not fix the problem , then there is an internal fault in the printer.
Regards.
Jun 01, 2009 | HP DeskJet D1460 InkJet Printer
Printer is not geting my print commands
What driver are you using on your vista machine? It would be better to load a local printer on your laptop and create a standard TCP/IP port using the address everyone else is using and load the driver locally instead of network printer. Also if you are using a print server to make it networkable you probably need the GDI version of the print driver loaded not the PCL5 or 6. It can be downloaded from sharpusa.com. PCL driver only works if PCL Print option is installed on the device. This would also give you a nic port on the copier as well, so if you have print server you probably don't have that option. If you need more specific details let me know.
Hope this helps,
TankMurdock
Apr 24, 2009 | Sharp AR-M205 Copier
Can not print to network printer
Do you mean you can ping it? If you can't, then disregard, my instructions below
You downloaded the latest "Vista" driver? then you went to"add Printer", Selected "Local Printer", then "create new port", select "standard TCP/IP port" typed in the proper Ip address of the printer? The wizard should find it and show it as using "Ricoh type C adapter" or similar, (if it moves on to the "select generic adapter" something is wrong) select have disk, and browse to the location of the unzipped printer driver, and install
Feb 26, 2009 | Ricoh Aficio 1035 Copier
Canon multipass F50 cannot get machine to print from my xp laptop
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Printer busy/or error
Sounds like your machine is using DHCP, not a static IP address?
Print your network settings from the Printer, then try to Ping from a computer on the network.
Check the Network setting of the machine, make sure it is set to a fixed (static) IP Address.
If this is the problem, you can go into your PC printers port and change the port to the reassigned IP Address of the machine.
If you reinstall the drivers then you will have this installed twice, one will work one will not, so delete it from the printers folder before you reinstall before you reinstall
Sep 28, 2007 | Sharp AR-M277 Black and White Copier
Getting HP2600n to print from MacBookPro first generation
Maybe you already tried this, but I think is worth asking: Is your printer installed on the right port ? Is your print queue empty ? Are you using the latest HP drivers ?
Aug 06, 2007 | HP Color LaserJet 2600n Printer
Canon ImageClass D880 Copier Logo
55 people viewed this question
old marine
old marine
