Question about Bernina Activa 130
Won't turn on
I just used my Bernina 130 yesterday and it ran fine. today when I went to turn it on it won't. I have tried different outlets as well and it still won't.
  • 46 Answers
Have you checked that the plug is pushed RIGHT into the machine?
Posted on Oct 24, 2008
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Using my Bernina 440 qe in the embroidery mode needle is hitting the foot.Worked fine yesterday, today I have broke 3 needles.
could you possible have attached a foot that is not the correct one for your Bernina one that is a smaller mm
Mar 03, 2014 | Bernina Sewing Machines
Can Bernina walking foot with soles and seam guided used on Activa 210 be used on 16 yr old Bernina Activa 230????
Please be advised that the newer machines (Classic models) such as the 130-180 and up, have a totally different geometry. This is to say that the older machines have a shorter distance from the center of the presser bar to the needle center. The newer machine design was increased to provide space for needle threaders etc. Older machines will use an older Walking foot model (still available).
Feb 27, 2014 | Bernina Activa 130
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I have an activa 130 and the foot won't go all the way down
Is your machine fitted with a knee-lifter ? If so, its possible the knee-lift mechanism has got stuck, which will prevent the foot from coming all the way down. It's also possible that the foot lifter bar has slipped which will require re-setting. When the foot is lifted and the feed-dogs are dropped, there should be a clearance of about 7.5mm between the underside of the foot and the stitch plate.
Mar 02, 2012 | Bernina Activa 130
My Bernina Activa 220 won't turn on. This has happened before, and I've always tried plugging/unplugging, switching outlets, etc. In the past something has eventually "worked" and once...
Could be almost anything ! Do the usual simple checks - fuse in the mains plug (should be 3A), have you got another piece of equipment (radio etc.) that uses the same 2-pin plug for power - use it to check that the mains cable is OK. If the mains cable is OK, it maight be the switch on the power supply module or the power supply module itself ('L'-print), but could be more ... check if the sewing light or display backlight is coming on, but if completely dead, your only solution is to get it checked-out by a Bernina service agent.
Nov 05, 2011 | Bernina Activa 130
Bernina Activa won't turn on
Lets start at square-one. Have you checked the plug fuse ? Have you checked that the 2-pin mains plug is firmly inserted into the socket on the back of the machine ?
If yes to the above ... are there any lights on at all ... sewing light, display backlight ?
If it's completely dead, it's most likely the power supply 'L'-print which is a separate module screwed into the back of the machine below the spool holders. Your best bet is to get the machine checked-out by a Bernina service agent.
Oct 28, 2011 | Bernina Activa 130
My Bernina Activa 240 won't turn on. I checked the outlets and they are fine. I even plugged it into different outlets hoping for something to work and it didn't. Can I take it apart and fix it...
Likely the problem is a blown fuse in the S-Print (power supply). You must have a grounding wrist strap when working with a Bernina Activa. They are extremely sensitive and can easily destroy the main circuit board if you don't use a wrist strap. You can get one at Radio Shack for less than $5. The power supply is the square 1/3 of the machine on the back on the handwheel side. You can remove the power supply by removing the long torx screw on the rear of the machine and tilting out enough to unplug the connector. Then dismantle the power supply until you can get to the fuse. Test the fuse with a continuity tester. If the fuse is blown, buy an exact fuse. Don not deviate. If the fuse is not blown, you may need a new power supply.
Jun 02, 2011 | Bernina Activa 140
Sewing Machines Logo
172 people viewed this question
Top Bernina Sewing Machines Experts
Bargain Box
Bargain Box
Derek Massey
Page Gettman
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
