Question about Maytag MER6769 Gemini Electric Kitchen Range
F1-8 error message & oven turns on to bake to 350 degrees; won't stay off
I have a Maytag Gemini stand alone double oven MER6549BAW oven. Recently out of the blue, it started beeping as well as turning on -- the upper oven would set itself to Bake, 350 degrees. Thank Goodness I was home to discover it and that there was nothing inside the oven as it had gotten itself very hot by the time it was discovered! Maytag says they don't have any recalls on this oven for this problem-- it is hard to imagine that my oven is the only one! This could have been a very serious fire hazard!
This oven is about 7 years old and was about $1,000 at purchase. New part it supposedly needs is a $400 circuit board. I am surprised that there was not a fail safe devised so that during a computer glitch, the oven would not heat up. Does anyone have a similar occurrence? Know why this happened? Will it happen again even with a new circuit board?
  • 833 Answers
SOURCE: Oven will not bake or broil
bann...why did you replace the element? It is possible that the relay or the control circuit were the problems and still are. The hi limit switch is a temperature 'box' which is designed to open the circuit in case of overheating. Rarely a problem. First, these units are 3 wire units. That means 220 volts ... two breakers. They may be part of a linked unit or separate. Turn them BOTH off and then on. Do all of your burners heat properly on high? If you have a voltage tester, you can test to see if the voltage is there. Unplug the unit. The vertical slot is neutral. Each of the other slots with the neutral should light the tester. If not, your problem is outside the stove.
Posted on Dec 12, 2007
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
shinn8
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
  • 67 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
you need to replace the oven ignitor
Maytag317
  • 1136 Answers
SOURCE: baking element not working
Hi, UNPLUG the oven! Remove the screws that hold the element in and pull it toward you. Hopefully they were kind enough to give you plenty of wire to pull it out. Then just unplug old element and plug in new one. Some models have a screws on the element to hold the wire on to it.
I hope this helps.
Please let me kow if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
Maytag gemini electric ignition won't shut off
Your valve switches are defective. Sometime they will do that if you recently had a boil over and they have got wet. Try turning the breaker off for 24 hours to see if the fixes the problem.http://www.on-timeappliance.com/ovenrepair.html
Mar 27, 2012 | Maytag Gemini 30" Self-Cleaning...
I have a Maytag Gemini range and the bottom oven is off by 25 degrees. When I set it for 350 it only gets up to 325 actual temp even though the digital display says 350. Is there an adjustment or do I have...
Sorry to read about your problem, I hope this helps you out.
OVEN TEMPERATURE ADJUSTMENT
If you think the oven is operating too cold or hot, you can adjust it. Bake several test items and then adjust the temperature set- ting not more than 10° F at a time.
To Adjust: 1. PresstheBAKEpad(upperorlower
oven) and enter 550° F.
2. PressandholdtheBAKEpad(upperor lower oven) for several seconds until TEMP ADJ is displayed.
3. PresstheAUTOSETpad-eachpress changesthetemperatureby5°F. The control will accept changes from -35° to +35° F.
4. Iftheovenwaspreviouslyadjusted,the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F.
5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini double oven flashes F1 and stops heating.
I am attaching a Gemini manual. The checking procedures are the same for your oven.
Two component suspects for your problem would be the door latch mechanisms and the oven temperature sensors.
http://www.servicematters.com/maytag_library/docs/16010161.pdf
Feb 03, 2010 | Maytag Gemini 30" Self-Cleaning...
Oven won't stay hot
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG
Feb 12, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag MER6769 Gemini Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
