Question about Xerox Phaser 8500N Printer
Error code 09,036.44:10394
I have a Xerox phaser 8500 with a code of 09,036.44:10394 ant idea what this code is and a fix. We still have not gotten our service CD.
  • Mill Bullard Nov 15, 2008
    09,036,44 what is it thanks.
  • 7 Answers
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
Phaser 8500 error code 19,003.48:64663
19.003:48 is the error code 64663is the number of pages the unit has printed. the error indicates a power difference of +- 20% when trying to drive the printhead. The issue is the Electronics Module (System logic and power) or the Wave Amplifier (Printhead Controller). Both of the parts are fairly easy to replace. If it is the wave amp it is a somewhat affordable part.if it is the EM you should replace the printer. It isn't worth the fix.
Dec 12, 2013 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 19003.48:33702
19.003:48 is the error code 33702 is the number of pages the unit has printed. the error indicates a power difference of +- 20% when trying to drive the printhead. The issue is the Electronics Module (System logic and power) or the Wave Amplifier (Printhead Controller). Both of the parts are fairly easy to replace. If it is the wave amp it is a somewhat affordable part.if it is the EM you should replace the printer. It isn't worth the fix.
May 21, 2012 | Xerox Phaser 8500/DN Printer
:I have a Xerox Phaser 8500 with the following error: 13.323.47:31989. Any ideas what this is?
This fault code is saying that the printhead reservoir thermistor circuit is open. Unfortunately, only a printhead replacement will solve this problem.
Jan 09, 2011 | Xerox Phaser 8500N Printer
Error code 37,016.43 Xerox Phaser 8500 Printer Problem I get this error when I power up. Printer won't do anything. What can I do to fix it?
This is an internal power supply error. The 50 Volt supply has a fault, or there could be a short on the supply rail.
There could be an error in the Head Maintenance, Deskew, or pick clutches.
I think you will need a qualified technician to fix this.
May 25, 2010 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 09.005.40:64314
Best way to do that is take a screw. I use a drywall screw, and twist them into the blocks and slide them back and out. Remove all of them, see if there is just one stuck or not compltely advanced in the loader. Then replace them all . That should clear the code.
Feb 03, 2010 | Xerox Phaser 8500/DN Printer
I just installed a new control panel for the phaser 8500 and now get an error code 13327.42:6027
13,327.42: The Printhead reservoir thermistor returned a bad reading.
  1. ensure that all the components are grounded properly
  2. Run the printhead RESERVOIR TEMPERATURE test on the diagnostics menu. If fails replace printhead.
  3. Check and reseat all wiring to the printhead. If all connected then replace the printhead.
Most of the times that i've gotten this error I've had to change the printhead. Anyways good luck.
Dec 03, 2009 | Xerox Phaser 8500/DN Printer
PDF documents do not print completely on my Xerox Phaser 8500
I am having the same problem. Sometimes my Xerox Phaser 8500 prints a PDF or web page fine, and other times I get pages and pages of what looks like PostScript code. I thought I had installed the most recent printer drivers, We are using primarily Macs with OS 10.4 or 10.5. One recent change is that we connected the printer to an Airport Express using a USB cable, which is sweet when it works correctly....any ideas???
Jul 14, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 fault 37,008:44:11605 What is it?
The 37 series faults are usually due to the failure of one or more heaters in the print head. Usually a comparatively inexpensive fix if its just the electronics module(part no:119649580). You will definitely need a tech's assistance to fix it. If the printer is under warranty they XEROX should do it for you free of cost. Hope that helped.
Sai.
Jan 12, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500N Printer Logo
192 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
