Question about Crossfire VR404 Car Audio Amplifier
Internal malfunction? OK so this amp used to work perfectly, but now when i turn it on everything seems fine, only once i turn my CD player up past 20 (which really isn't loud or anything) it goes into protect mode. no speakers are blown or anything so i would rule that out. any ideas?
  • Anonymous Feb 15, 2009
    i have the same exact problem. it worked a week ago but now it is going in and out of protect mode!
  • 35 Answers
Need new ground wire, possibly bigger gauge wire, may need to take cd player out and re-hook the wires up into the cd player then into the amp to make sure no wires are touching
Posted on Sep 16, 2008
CD player works but start delays from 5 minutes to 20 minutes. What could cause that?
Dust inside the cd player could be causing problems.
You need to try playing a cleaning cd and follow the instructions that come with it. You can also spray compressed air to clean out the cd portion of the stereo. You can also try unplugging the unit for 20 minutes and then plug it back in. Make sure your cds are clean and not too scratched up. If the unit is under a year old it may still be under warranty. If this does not resolve the issue you may have to have the unit professionally repaired. If the unit is not worth repairing you may need to buy another unit.
Nov 02, 2015 | JVC UX-T3 Shelf System
I have a CD and in my car it won't playback discs. It allows me to insert/read the disk, it even shows the data, track number, and position in the song but it won't play to my speakers. The AM/FM...
What i found i have had that problem in the past,This may sound stupid but it works.Spray aftershave over the cd then push the cd into the player when the aftershave is wet.This will clean out the dust inside your cd player .i can say this will do no harm.ok pippall,Hope that solves it for you m8.
Aug 24, 2011 | 2003 Toyota Corolla
Sony cdx-gt300 AM radio malfunctioning
If no AM and everything else is ok , the unit needs to come ouit for repair...keep in mind that these are cheaper to replace than repair.
Mar 11, 2009 | Sony CDX-GT300 CD Player
Video not playing correctly sony nw a808
ummm u can try what im doing because its working perfect for me i have converted around 20 vids all perfect so here
i use Xilisoft HD video Converter (if u need i can send you just email me) i have cdkey too ... but yah while in the program i use the blackberry setting so that the screen is just the right size not to big or small color n everything is fine and yah if nething else u can just ask me hope this helps
Feb 08, 2009 | Sony Walkman NW-A808 MP3 Player
1996 dodge avenger
sounds like your having a problem wiring the cd player. are you using the correct wiring harness? I just installed a cd player in my 1996 avenger and had no problems, the only thing i had a problem with was that the stock radio was malfunctioning seemed to be fixed once i installed the new cd player
Sep 25, 2008 | 1996 Dodge Avenger
You must run a repair using the Philips Device Manager that came with the CD. After you have done that, you must run the "update" with the Philips Device Manager.
Repair=1 time fix
Update=permanent fix
Jun 08, 2008 | Philips GOGEAR SA6045 MP3 Player
At high volume sound shuts off, subs still work
You most likely have a shorted or damaged speaker, which is causing the internal amp chip to shut down (but does not affect the preamp outputs). A test you can do is to fade to one speaker at a time and turn it up to se if it shuts down. Repeat with each speaker until you find the one that causes the fault. Then replace it.
Dec 08, 2007 | Pioneer DEH-2100 CD Player
No Power At All
I have the same problem with my sometimes. Sometimes it is working fine and when I turn the car back on, it won't go at all. On the back of the head unit, there is a reset button. Press the reset button then press the power button and it should work.
Oct 14, 2007 | Lanzar VBD1200 CD Player
Amp turns on then starts making subs go erratic with almost sounds like line nosie
hi i had the same problem people suggest checking ground thats where you start at then if it aint ground for sure, the make sure you have good rca cables. If there good this is what happen to me i had a cheap ole pioneer 70 doller cd player the actual rc jacks from that cd player was making and horrible sound travel through my speakers im talking humming whinning everything im positive that this will solve your problem email me at and let me no something if i helped or if ya need more help
Apr 04, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Crossfire VR404 Car Audio Amplifier Logo
100 people viewed this question
Top Crossfire Car Audio & Video Experts
xxxxxx xxx
Rommel Balcita
Are you a Crossfire Car Audio and Video Expert? Answer questions, earn points and help others
