Question about Microsoft Xbox 360 Console
Xbox360 how did u fix your problem where it wouldnt read anything and it would keep saying open tray? i would really appreciate your answer..
What do you do win you clean the disc and rest the xbox
Posted on Sep 19, 2008
  • 31 Answers
Keep repeatly doing this it will eventually work after 20 times but your disc drive is failing you need a new one and installed you can get one at http://store.richspsxparts.com/imnooninxb36.html
Posted on Sep 18, 2008
Xbox360 console wont read game and keeps saying tray open when it is not
You can refer to this page for the information and fix on your problem. It will saves time and money
Thanks for using Fixya.
Jan 31, 2011 | Microsoft Xbox Console
My console keep saying open tray and won't read any disc
this is a very annoying problem when the disk drive is going bad (sometimes you can tap the top of console while its loading and it will read) you will need to send it off to get it fixed which is about the same cost as getting a refurbished console now or you can take console apart and change it yourself. takes about 30 min to do this. There are several different disk drive open them and you will see marking on disk tray Mitsubishi/samsung/benq are the ones I've fixed and repaired so far check out youtube under xbox360 disk drive replacement for visual guide if you don't know how and http://www.llamma.com/xbox360/Xbox_360_DVD_Drive_Comparison.htm to determine which drive you have and shop around for best price. good luck
Dec 22, 2010 | Microsoft Xbox 360 Console
I put in game disc or dvd in my xbox360 and instead of saying reading it keeps saying open tray.
Yes the disc reading problem is quite bad all you need to do is use a good repair guide or you can send it in and they will fix it for you.
Aug 28, 2010 | Microsoft Xbox 360 Console
Disk tray is not spinning
The way to fix this is to open the disk tray and blow inside for about thirty seconds getting the dust out of the way of the laser also blow across the disc tray and the surface of the disk. Then keep closing and opening the tray and it will start to read hopefully. if this does not work go out and buy a disc cleaner. it looks like a disc with sponges on it and when you insert it into the console it cleans the inside for you. Sources: i am going through it right now internet my personal experience
Apr 08, 2010 | Microsoft Xbox 360 Console
My xbox360 console wont read the disc. It keeps reading and then says open tray. How do i fix this?
well clean the disk. first of all second of all try another disk. if this works then it's a problem with this one disk and the souloutin to this is to play it from ur hardrive , hope i helped :d
Apr 06, 2010 | Microsoft Xbox 360 Console
Xbox is not reading any discs, says open tray
Open tray error is common, even more so on Samsung drives.
To fix this you usually really need to open your xbox360 so you can get to the disk drive so you can open it for a self serice. BUT first try to fix it with a laser cleaning kit, they dont cost much to purchase and you can get them from most electronic shops and also ebay.
If a cleaning kit did work then the problem may be your tracks, the disk spin head or the belt that moves the tray.
Once you have your xbox360 opened (lots of good video guides on youtube on how to open the xbox360) you will have to open your disk drive.
When its open, clean the left and right tracks, they can get gummed up with dust, and even tar if the unit is from a smokers home, when the tracks are dirty, it can stop the tray going in all the way then games dont play. Also if the spin head is dirty (the plate the disk sits on to spin the disk) then it does not grip the disk fully and thus does not spin at full speed, giving you read error. Finally the belt inside the drive can be removed and can be boiled in water for a minute or to, this cleans it and brings it back to its original shape, this helps the belt regain lost grip and can also fix this error your having, but belt problems are more for samsung drives.
You should use rubbing alcohol to clean the internal comonents of your drive without causing any damage, you could even clean the laser yourself using a high quality kitchen roll sheet or micro fiber cloth, with rubbing alcohol and gently pass it over the lens to clean it. Once you have done all this, close everthing back up and see if the problem is gone.
If your still having problems then chances are you need a new laser for your drive.
The following youtube video may help you http://www.youtube.com/watch?v=6GLS1dndQLU
Let me know if you need more help.
Jan 02, 2010 | Microsoft Xbox 360 Console
My xbox360 keeps asking to open tray on load up or close tray.it will miss read a game as a dvd AND SAY PLAY dvd .It says clean disc when i just have done half a dozen times
your dvd board is going out or your laser is screwed as this as happened to mine before. get it repaired. i have no idea how to fix it without a personal repair. if you had to repair it yourself, i would consider switching out your laser.
Dec 12, 2009 | Video Game Consoles & Games
The game tray will not open on my xbox360
this is a rare problem for a xbox360 but dont worry ill help you out as much as i can. try taking apart the 360 (but be very carefull bot to pull any wire or break somthing)it just might be dirty or disk reading problems. take the consle to a local game stop and get there opionion or just call microsoft and they'll help you out with a warenty.
Dec 16, 2008 | Microsoft Xbox 360 Console
Xbox360
no the eye is either dirty or broken did you get it wet or did it fall off something
Mar 15, 2008 | Microsoft Xbox 360 Console
How can i fix my xbox 360
get a qtip and open the top of the xbox 360 and anything u c thats dusty clean when done close it
Feb 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
