Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
Unlock me i have a garmin and i never set the lock code my nephew locked it playing with it.any suggestions
  • Garmin Master
  • 2,130 Answers
Model please?
Here's your options:
1. Enter the correct PIN.
2. Go to the secure location where the PIN was set and it won't ask you for a PIN.
3. Send the unit back to Garmin to be unlocked.
Sorry but there is no master reset. The PIN is written into memory that can not be erased. I have had success in unlocking Nuvi's but I will only do it for people who have a valid purchase receipt from a major retail chain and if they can provide me with their Garmin registration info so I can verify that they are the rightful owner.
There are too many of these units out there that are stolen and the culprits are looking for a way to bypass the PIN. This is why Garmin added this feature to their GPS's.
- Jim
Posted on Sep 15, 2008
Has a lock code on it how can i unlock the code
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} : If you have a Garmin Lock on your nuvi series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device. (Approximately 150 feet from that location)
Nov 08, 2009 | Garmin nuvi 260W GPS Receiver
I recieve a garmin as a gift @ it now has a code lock on it how can i unlock my garmin 260
The Garmin Lock is a theft-deterrent system that locks your nuvi. Each time you turn the on the nuvi, you would have to enter the PIN or drive to the security location. (where it was orig programmed)
To set the Garmin Lock on the device:
  1. From the Main Menu, touch the Wrench (Tools) icon.
  2. Touch Settings.
  3. Touch Security. (you may need to touch the down arrow button)
  4. Touch the tab labeled Off next to the Garmin Lock heading.
  5. The nuvi will prompt you to enter a four-digit pin number.
  6. Enter a four-digit code as your pin.
  7. Re-enter the four-digit pin.
  8. Go to a 'Security Location' and let the unit acquire satellites (the security location will unlock the unit if the pin is forgotten or lost).
  9. Set the 'Security Location' by touching Set.
The Garmin Lock has now been turned On.
Unlock nuvi 680 na please
I think you have to send it back to Garmin. Liam
Jun 17, 2009 | Garmin Nuvi 680 GPS Receiver
Gramine gps is locked with a pass word.
Thankfully the solution is very simple to your problem. The only way for the Garmin to accept a setting of a password is if you also define a secure geographical spot right after the PIN code setting.
If no safe place is defined, the lock will not engage and the PIN setting attempt is void. So if it is locked it means your daughter has stored a safe location as well (you just click ok so it is easy also for a 3-year old).
At this geographical spot the GPS unit will be unlocked, and you will be able to change the PIN code to your liking or remove the lock.
So all you need to do is to recollect the specific geographical place your daughter may have played with your GPS, bring it to that place and switch it on: no PIN code is asked for when you found the correct spot. You may need to wait a few minutes for the unit to locate satellites, then it should unlock.
Jun 03, 2009 | Buck BENNETT DVD GARMIN NUVI 750 760/770
HOW CAN YOU UNLOCK A CODE LOCKED UNIT if you dont have the code?
No, unfortunately. You either need to drive to the secure place to unlock it, or contact Garmin to have it unlocked. Once unlocked, I would recommend turning Garmin Lock OFF.
May 20, 2009 | Garmin StreetPilot c550 GPS Receiver
My garmin nuvi 660 na is locked and i cant unlock it
There should be a small pinhole for a reset button. Press and hold this reset button for 60 seconds. Then turn the device back on.
Mar 25, 2009 | Garmin Nuvi 660 GPS Receiver
Unlock code for my garmin nuvi 350
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Jan 02, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin gps how to unlock it
you cant unless you know the code that the persons put in to lock. you got burnt if you got them from someone. If you get a new one MAKE SURE to put a lock code in you can remember then if a child etc plays with it and locks it you can still use it . You have to know the code only way.!
Nov 02, 2008 | Garmin nuvi 350 GPS Receiver
Unlock c510
Take the unit to where your nephew was playing with it, and it will automatically unlock. Otherwise, you'll need to send it in to Garmin with the receipt from an authorized dealer.
Sep 06, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin streetpilot c510
You cannot unlock (or "reset") a locked unit without the PIN number or going to the location where the PIN was set. The only other option you have is to send the unit to Garmin.
Dec 19, 2007 | Garmin StreetPilot c510 Deluxe GPS...
GPS Logo
128 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
