Question about Maytag PAV2300 Top Load Washer
May tag washer will not agitate, spin water out
I moved to new house washer just fills, will not agitate spin out water. Working great before washer was moved. Is ther a reset button or something on maytag washers?
  • francis rivero May 11, 2010
    does it fills up to overflow?..i mean it would not stop from filling the tub until it overflows?
    tnx ,
    drcool
  • 943 Answers
Hi i would check the water level control
Posted on Sep 26, 2008
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
WASHER FILLS WITH WATER AND AGITATES FOREVER. I
Based on your discription you do need a new timer.
Jun 11, 2010 | Hardware & Accessories
Wont fill or spin runs dry
Check the water pressure switch for proper operation
Oct 19, 2009 | GE WBSE3120B Top Load Washer
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Maytag washer will not fill with water. It does agitate and spin
My May Tag model LA 882 washing machine is not draining water. the water remains even after spining and the cycles are longer durations. any advise ?
Mar 31, 2009 | Maytag Washing Machines
GE Washer Model WJSR2080V3WW Agitates, Pumps, but will not Spin
I solved the mystery of the non spinning washing machine by GE. I pulled the agitator off and to my horror was a broken " hub". This the part in the middle of the basket under the agitator. The transmission shaft comes up through the center of it. Any way, it was severely broken and wedged in so it would not spin. Not sure if this is the only problem but I am going to buy a new machine. I can not get it unbolted to replace the hub and don't want to **** around with it. THANKS.
Jan 25, 2009 | GE Washing Machines
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Maytag PAV2300 Top Load Washer Logo
317 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
