Question about Garden
Murray lawnmower My mower runs for a moment then dies. I think I may need to clean the carburetor, but I don't know where it is. My model is 20112x92a
  • kennetharno Sep 23, 2008
    I HAVE A 3.75 THAT DOES THE SAME THING RUNS THEN DIES
  • sassyass3814 Oct 20, 2008
    I do have the same problem, I have changed the plug and there is oil and of coarse made sure there is gas also, now what should I do?
    Problem Solver:
  • 5 Answers
You may just need to remove the nut that holds the float bowl, and inspect the nut itself, half way up the nut should be a little tiny hole in the side.
use a bread tie stripped of the plastic covering and unclog this little hole, then replace the nut , when that hole becomes plugged the main jet cannot get fuel for the venturi pipe, thus the mower will start and hit a couple times then die immediately, that may fix the problem
Posted on Jul 29, 2009
I have the same mower, a 2004 murray 20112x92a and just tore down the carb only to find out the hardware store didn't have the diaphram part. The mower ran fine for 10 minutes until I turned it off. I went to start it 5 minutes later and it does the same thing again -- start and then dies.
I think its the carb bowl, does anyone have a video on how to tear it down? its not a simple as removing one bolt on this model, also its the briggs and stratton motor
Posted on Jul 16, 2011
  • 48 Answers
Sounds like either water in carb bowl or plugged high speed jet - if you dont know what a carb is its not something you better do yourself send to nearest repair shop -
Posted on Oct 21, 2008
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
I have a Murray model number 20213a it will start and run fine but only for estimated 3 seconds then shuts off.why or wat could that be?
It's not getting enough fuel, Check /replace the fuel filter first but you may need the carburetor cleaned
May 03, 2015 | Murray Garden
Dynamark 3.5 Model 20211X18A. Looking for manuel, I prime 2 times to start. Engines starts then dies. If I continue to push prime button it will keep running, barely, however, dies as soon as I stop...
Could be 2 things: a restriction in your fuel line/coming out of the tank, or 2: a dirty carburetor needing to be removed, cleaned and possibly rebuilt and reinstalled. Hope it's one of those.Start with pulling the fuel line loose from the carburetor. If you have fuel flowing freely, plug the hose with a golf tee and move onto removing the carburetor. Carb kits are cheap and easy to install. It's best to rebuild while you have it off to avoid similar problems later.
Sep 30, 2013 | Briggs & Stratton Briggs Stratton...
When I try to start my Craftsman Model # 917.388861 lawnmower, it will start and then dies right away, then Iit would start unless I prime it. Before it started doing this, the lawnmower was running very...
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Aug 16, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
I can crank my murray gas lawn mower 6.5 quantum
Sometimes you can get by with priming it a few times, and letting it
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
When you clean your carburetor and remove the jet screws, count the
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 08, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Murray 22'' 6.0 hp gas lawnmower engine dies right after start up.
SOUNDS LIKE YOU NEED A FULE FLUSH AND CARB KIT
Sep 27, 2009 | Garden
My lawn mower tries to start but then dies shortly thereafter.
Probably. Does it start after you push the primer and then die? If so, yes, it's the carb. For any more info, I'd have to have the model and type #'s off the engine. Dwain
May 17, 2009 | Craftsman Garden
Garden Logo
512 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
