Two NEC T-601E FM Tuners: 1. Distortion on FM and FM stereo reception. Don't know about AM. 2. No reception at all.
SOURCE: Loss of reception in 2002 ford focus factory radio fm
More than likely the antenna cable has come loose from the back of the unit. Head to Walmart and get a removal tool, pull the radio, and resecure it.
Posted on Mar 12, 2008
  • 51 Answers
SOURCE: Service engine soon light, radio am not working, dashboard lights
is there enough charge in the battery or have the light bulbs gone in the dash?????
Posted on Jan 27, 2009
alicantecoli
  • 22265 Answers
SOURCE: no AM radio, very weak FM radio reception
i would pull set out and have a look at the printed circuit from the aeriel to where ever it goes to in the circuit board ,if i couldnt repair it ,then i would have a nice drive to carrefour(hypermarket) and buy myself a belson which has usb/sd card/cd and they do one with blue tooth all for about 100€ and fit that .who needs a cd changer when you can put a 2 gb sd card in that can hold 40 +cds or plug your i pod in
Posted on Feb 16, 2009
awcforever
  • 359 Answers
SOURCE: no am reception and poor fm reception - 2004 Kia Sedona
If the antenna is on the front, pop the hood, and locate where the antenna wire connects to the bottom of the antenna and make sure it is connected well. If everything checks out there, you will have to pull the radio from the dash, and look at the back of it. There will be a large black wire by itself connected to the radio. Push it in to make sure its connected as well. That could really be your only problem unless your radio happens to have a fault on the inside which is extremely rare. Hope that helps
Posted on Mar 15, 2009
SOURCE: Digital reception
Hi
It is Impossibil.
ruud
Posted on Apr 10, 2009
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Pioneer F-Z92 receiver. Intermittent reception on both AM/FM drops out altogether.
Are the amps working on other input sources? If not it could be the amp section of your receiver causing the issue.
If amps are ok then it has to be a circuit that both the am and fm tuners have in common since both are affected. U would need a schematic to identify the common area (s).
Feb 24, 2016 | Pioneer Audio Players & Recorders
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory » FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
What am I doing or NOT doing that causes the stereo buttons to be inoperable?
Wish I could help you but I cant. I just wanted to comment that your question has great information compared to most questions with vague information.
Oct 22, 2015 | Lexus Cars & Trucks
Can i connect an external antenna to a sanyo awm 2000u stereo for better tuner reception?
Your stereo came with a piece of wire attached at the back. This is/was the FM aerial. It should be roughly 1 metre or approx 38" long. There is no socket on the back of this stereo to attach an external FM aerial. So if the wire broke off then you're going to have to either attach some new wire to the stub, or open the set up and solder directly to the circuit board.
The exact cable lengths for an FM antenna to pick up 88-108 MHz is 37.66" long.
Sep 12, 2014 | Audio Players & Recorders
I have hooked up all the wires in the appropriate color-coded order and my stereo has no reception. It has power but no reception. The antenna is hooked up also. It is a Kenwood KDC 119 and the vehicle...
Selecting the station. 1 Select tuner source Press the [SRC] button. Select the "TUnE" display. 2 Select the band Press the [FM] or [AM] button. Each time the [FM] button is pressed it switches between the FM1, FM2, and FM3 bands. 3 Tune up or down band Press the [4] or [¢] button. During reception of stereo stations the "ST" indicator is ON. 1 Select the band Press the [FM] or [AM] button. 2 Select the frequency to put in the memory Press the [4] or [¢] button. 3 Put the frequency in the memory Press the [#1] - [#6] button for at least 2 seconds. The preset number display blinks 1 time. On each band, 1 station can be put in the memory on each [#1] - [#6] button.
Nov 03, 2010 | Car Audio & Video
I have a new Onkyo TX-SR508 receiver. When listening to FM radio the audio cuts out repeatedly for anything from a few seconds to a minute. Power fluctuation is very unlikely to be the problem. Signal...
Does the display show "tuned" or "FM Stereo"? This would normally indicate a good reception. The tuner has a signal level threshold and if the signal gets to week, the receiver mutes to prevent noise in the speakers. Swithing to mono make reception less intolerant. Does the problem also occur, when you switch to mono?
Jul 14, 2010 | Onkyo Audio Players & Recorders
Reception on fm is not very good
Unfortunately there are only two real ways the reception could be "bad".
Either your MP3 player is a lemon itself (meaning a single defective product, in which case you can return it, if you bought it recently!)....OR, the more likely answer is that MP3 players with FM tuners generally don't have great reception.
I have run into one MP3 player that has pretty good reception, and that is the Zune. It lets you set presets and such as well. Hope that helps!
Jun 25, 2009 | Sony NWZB133F MP3 Player
71 people viewed this question
 Grubhead
Grubhead
